Question about Saniflo & Saniplus& Macerator Pump
Our macerator allows water to go to top of toilet bowl and the maceraor itself seems to be leaking water on to the floor. Any ideas?
  • 33 Answers
Blocked or VERY dirty saniflo. This unit will have to be removed for complete cleaning and descaling. check the 22mm outlet pipework for blockages. Once spotless, check the unit for operation and then reinstall. Se my other posts for how to.
Posted on May 10, 2010
The bath water won't pump out. Seems like there's too much water left in the Saniplus itself to allow the bath inlet valve to open. Can this be adjusted? The toilet and wash basin are working OK.
This is a bit of a puzzle, if theres water in the Suniplus then the float valve will operate and the water will pumped out as it does for the toilet and wash basin.
I can only think that the bath discharge none return valve is stuck and needs removing and cleaning.
Hope that solves the problem.
Alllan
Mar 26, 2015 | Saniflo SaniPlus-Round SaniPlus Macerator...
My neighbours saniflow toilet is drivng me mad. The motor keeps whirring every 5 mins. Whats the problem, please!
Water pressure is what makes the unit kick on and off. If its kicking on by itself most likely water is somehow draining back into the pump. Start by checking the flapper in the flush valve inside the toilet tank, it may be leaking water into the bowl and from the bowl into the pump. Also inspect the check valve inside the 90 degree elbow where the waste is pump out from. The check valve may not be closing properly and is allowing waste water to drain back into the pump creating water pressure making the unit kick on and off by itself.
Oct 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflo pump turns on about every six hours or so on its own.what could be the ploblem?
Water pressure makes the unit kick on and off. Most likely somehow water is draining back into the pump. Check the flapper in the flush valve, inside the toilet tank and see if its leaking water into the bowl and from the bowl into the pump. Also, in the 90 degree discharge elbow there is a check valve with a rubber flapper that opens up to allow waste to pump out and it closes to prevent waste water from draining back into the pump. The check valve may be defective or it may be stuck open allowing waste water to drain back into the pump and is making the unit kick on and off by itself.
Apr 03, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
I have a toilet with a push button flush mechanism (allowing half or full flush). The toilet has a macerator behind it. If you flush the toilet and the macerator jams, the push button stays stuck in and...
This seems like a problem with your cistern and not your macerator - I have a similar set up and if your push button is stuck you need to check the mechanism in the cistern - also you should have an overflow that drains into your loo within the cistern so you should check this for blockages as well.
Oct 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
Pump cycles often
The following are the possible problems and solutions:
  1. The tank flapper (Flush Valve) leaking allowing water into bowl. Make sure flapper is fully seated. If flapper is fully seated and still is leaking replace flapper.
  2. Faulty Non-Return Check Valve, water leaking back into Macerator. Clean and Inspect check valve replace if after clean water still flows back into Macerator.
I hope this answers your question and gives you a few more places to look. Please rate the answer on it's helpfulness. Good Luck and have a great day. Jeff
Apr 06, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Seems to be leakage out of the hole on the top of the macerator tank
If hole has a carbon filter in it then this is the air vent. If water is leaking from here then a known fault so contact nearest sani engineer (2yr warranty). Check water is not dripping down from above first!
Feb 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I thought my macerator toilet must be blocked as it wasn't emptying in the bowl and when I flushed again the water (and waste) filled more into the bowl and leaked out of the top of the macerator spilling...
Typical saniflo costs about 500 quid incl vat from plumbase, prices vary according to what you need it to do.
It keeps making noise becasue the pump is still trying to get rid of the water inside.
it can't get rid of the water most likely because their is a blockage in the waste water pipe.
if possible follow where the waste pipe runs to. if it goes in to a loft or somewhere else VERY COLD there is a good chance that it has frozen somewhere along the pipe.
If you are tying to pump the toilet waste vertically (upwards) then as soon as you turn the power off to the saniflo, the waste will fall back down and in to the toilet - or over the top in your case, sorry!
You might want to accept the inevitable and get a bucket and start removing the waste water from the bowl. Make sure that you have rubber gloves and I suggest goggles and something protecting your mouth - in case you get splashed.
Easiest solution, is to remove the excess waste water, turn off the saniflo, pour some bleach in to the toilet bowl, then cover the bown securley with cling film to keep the rank smell at bay.
Other wise, start tring to follopw the waste water pipe and warm it up, either by directly or indirectly (warm air gun) or by warming the area around it.
Personall;y i am using the easy option. the cold werather won't last forever, but can you use a toilet elsewhere in the meantime.
In the meantime, Saniflo claim about 15 years as the lifespan, but i have never know a saniflo to make it past 3! they are not ideal, but may be your only option.
consider whether you could get a proper toilet waste pipe put in, as it WILL save money in the long run...
Hope this helps a little bit.
Mark
Jan 08, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo & Saniplus& Macerator Pump  Logo
451 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
