Question about Singer 14SH654
I have the 14SH654 serger i want to know if it has a straight stitch when you serge?
  • 10,515 Answers
It has a straight stitch when you serge.
Let me know if you have more questions.
Thanks.
Posted on Sep 09, 2009
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Where can I get a book to show me what it does?
SERGER:
A serger can do a lot of things. Frequently, they are used to finish raw seams and hems, but there's so much more they can do. It's mostly just a matter of experimenting and deciding how to apply it to your projects. I've even serged a strip quilt.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjLr5jft4fNAhUVK1IKHUJ1DkQQFggdMAA&url=http%3A%2F%2Fwww.peggyddesigns.com%2Fpdf%2Fyou_did_that_with_your_serger.pdf&usg=AFQjCNE3-5sHx4gwgk640NyspfXivuYzkw
You can download workbooks and work through them. (This is a Bernina work book site, but sergers frequently can do similar stitches.)
My BERNINA Workbooks
Sewing 201 Do need Serger
Serging Projects and Designs
Aug 18, 2015 | Baby Lock Sewing Machines
I just got a new Janome 8002d serger. Why does it make a clicking noise when I begin to serge and then it goes to straight stitching that comes unsewn.
I don't have a Janome, but you might check your threading to see if it's correct, lucky you to get a new one!!!
Mar 05, 2015 | Janome Sewing Machines
My serger won't stitch
Be sure you have new needles inserted correctly, threaded in order loopers then needles, check with diagram on machine or in manual to be sure correct. Still not working usually a sign of timing problem. Requires technician trained on serger repair.
Jan 09, 2014 | Singer 14SH654
Left needle not stitching on serger model 14SH654.
the needle could be damaged,,replace the needle,,if the needle is new make sure it's in the needle holder correctly
Aug 26, 2011 | Singer 14SH654
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
My serger sews what looks like a straight stitch that pulls right out. It appears to be correctly threaded, and was serging correctly. Now it doesn't!
Without seeing it I would say that it has slipped out from the tension discs on top. Rethread and use both hands to pull on your thread as you are passing it through the tension discs so that it catches. I know, it is a pain but it is your best bet. This happens more frequently than you know.
Apr 22, 2011 | Singer 14SH654
Changed thread on serge pro SW 432. Now no chain or stitch.
Sergers can be tricky to thread.
Remove the thread.
Raise the antenna to it's highest position.
Open the tensions - setting zero.
Lift the presser foot.
Open the door on the serger and turn the handwheel until the upper looper is at it's highest point.
There should be a threading guide on the front of the machine or on the inside of the door.
Follow the threading sequence as this greatly affects the stitching.
Mar 13, 2010 | Simplicity Serge Pro SW432 Mechanical...
Where can I get parts for my 1034D Brother sergers? I have 4 of them and just broke my last ..... I don't know what it is called, but you pop it in and the thread goes around it as it serges where all the...
I don't know if you still need this information but you're looking for the stitch finger. If you contact Ron at a1sewingmachine.com he can get you the part.
Jun 25, 2008 | Brother 925D Serger
Singer 14SH654 Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
