Question about Combi Centre DX - Mango
I have a britony combi se 80. It keeps cutting out, error 60.
I have a britony combi se 80. It keeps cutting out on both heating and hot water, displaying the error code 60 along with the red flame lockout. When it does run the flame light is very dim and seems to flicker abit. I have read it could be the PCB or Ionization electrode (and possibly flue alignment or gasket) but I am unsure if there is a way of finding out which part it required without going out and buying them all! Can anyone help with this? Thanks Jay
  • leachy922 Sep 13, 2009
    What do clean it with? and also which part is the retification probe? is that the electrode? Thanks
  • leachy922 Sep 18, 2009
    What is the retification probe, is this related to the ionization electrode? (May be a stupid question but I dont know) And how do I go about cleaning it?
    Thanks
    Problem Solver:
  • 13 Answers
Hi mate if you are happy to open the appliance and not disturb any gas connections clean the rectification probe, cause if its a intermittent fault it could be carbon deposits on the probe also make shaw the lead from probe to pcb is connected and not damaged if all ok its the pcb, let me know
Posted on Sep 12, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Chaffoteaux britony combi 80 I've just replace both pcbs and still have a pulsing flame after ignition. It burns for a few seconds then cuts out. Ideas?
this sounds like a central heating boiler rather than a computer. can you please post in the correct section where you'll get a meaningful response.
Mar 14, 2014 | Computers & Internet
Britony 80 combi boiler G31 propane, gas flow rate =0.124877 cubic meters per hour, inlet pressure 37mbar, room sealed flu Manufactures recommended Co2 & NFGT unknown, cold water from hot tap when...
You gave a good description of the boiler--
now we need to hear the clues you have observed, as it fires (or fails to fire-- or what?)
Or as the water flow-- or doesn't flow?
As the cold water enters-- what does the flame do?
And does the flow rate reduce as the flow gets to the divert er valve?
How old is the boiler?-- and have we been using HARD water?
(Any water softener in the circuit to remove calcium and magnesium, etc.?)
Do you suspect a scaling problem in the interior parts?
If so-- can you circuit an acid thru the innards, to clean up the scale?
Please comment on what happens when water and gas flow-- so we can help you get to the next step.
Mack B
Jan 17, 2011 | Heating & Cooling
I have Britony combi SE.It keeps cutting out error 70 and 80 . Ichance the pcb three months ago if that helps
tour gas valve or solinoid is faulty,check you have 240dc across the solinoid,if you have then its the gas valve,if not its your solinoid,but check you have spark at the ignition electrode first,if not check the continuity of the harness,the harness are the two yellow or orange wires from spark generator on pcb to ignition.
getting confused,mail me i will go through it for you
Jan 24, 2010 | Combi Centre DX - Mango
Britony Combi se 80 boiler
Steel wool is the way to clean. Hope this helps
Oct 18, 2009 | Water Heaters
I have a chaffaeux combi 80/100 no hot water
sounds like diaphagm valve or micro switch best of luck
May 06, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Combi Centre DX - Mango Logo
1,569 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
