Akai LCT3201TD 32 in. LCD Television TV/DVD Combo
Problem for Akai LCT3201TD 32 in. LCD Television TV/DVD Combo
Tv shuts off when you turn it on again it will play a minute
By eternalheirs on Sep 09, 2009
tv shuts off when you turn it on again it will play a couple minutes and shut off again . dvd stoped working about two months ago. This week a note comes on the screen that your battery is low. We put new batteries in the controls. Now the tv will not stay on
Best Solution
posted on Sep 21, 2009
Very Helpful)
codehunter
Rank: Master
Rating: 92%, 13 votes
I think this might be bad/swollen capacitors in your power supply, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the PS secondary circuit (may cause the red light blink or shutdown problems).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
OK for the Megmeet MLT169A with red flashing LED when turned on we found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Akai LCT3201TD 32 in. LCD
Questions and Unsolved Problems for Akai LCT3201TD 32 in. LCD
Do you recommend Akai LCT3201TD 32 in. LCD Television TV/DVD Combo?
Answer
Answer
turned on the tv, sound & picture came on, then everything went off and the red light in... (More)
Answer
Our picture pops and goes off when turning on t.v. sometimes if we unplug it and plug in back in it... (More)
Answer
when u turn the power on it does nothing but pop,
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
