Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
New ESP 3 printer recently stopped printing. Replaced ink, acts as if it's printing but nothing. Removed the cartridge carrier and see a buildup of ink on it but not getting to the paper. Any ideas as to why?
Kodak ESP-3 All-in-One-Printer still says black ink catridge is low after I replaced it
There is a sensor in the cartridge which contacts with the printer. See it is clean from dirt. Try reseating the cartridge. If you use cheap cartridge rather than genuine then this could happen.
Check for updates in the Kodak website appropriate for you.
http://support.kodak.com/app/intfSel/intf_redirect/L2FwcC9hbnN3ZXJzL2RldGFpbC9hX2lkLzE3MzAzL34va29kYWstZXNwLTMtYWxsLWluLW9uZS1wcmludGVyLWZpcm13YXJlLS0td2luZG93cy1vcGVyYXRpbmctc3lzdGVtcy9vcmlnX2ludGYva29kYWtfYjJjX2Vu
Dec 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
I replaced a new black ink catridge, the black is
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • Try changing the print quality to best then try printing
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 23, 2009 | Kodak ESP 5 Printer
Not recognizing brand-new ink cartridges
Check if:
* There was a ink leak from previous cartridges? If so, use a cotton cloth and alcohol to clean the cartridge connectors in the printer itself, not the cartridge. It will be a dirty job, don't touch your face or clothes while doing this because someone will think you a re playing "commando". [water may work but can damage it]
* Did you update the drivers for the printer? Check for new device drivers at the kodak website.
* Also, check the plastic seal of the cartridge as completely removed.
I didn't want to mention this, but you are experiencing a common failure of this kind of printers. If nothing of above works, that means the flat cable connected to the cartridges inside the printer may be broken. A technician may need to look at it, but it will be kinda expensive. Sorry pdxredhead.
Aug 29, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
42 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
