Question about HP Photosmart C6180 All-In-One InkJet Printer
HP 6100c printer/fax/scanner keeps restarting over and over
Keeps cycling through a power-up/power-down sequence.
HP website said that the problem is low power in an office.
NOT the problem; I unplugged the device and moved it to other areas of my house (where I KNOW I have adaquate power) and it STILL continues to do this.
I checked the power cord and re-connected the various parts, but this didn't help either...
Any ideas or solutions? The printer is only 2 years old. I had hoped it would last much longer as it's only used sporatically (a few times a month).
THANK YOU!
  • 100 Answers
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time.
HP 6100c printer/fax/scanner keeps restarting over - acca299.jpg
Posted on Jul 11, 2011
Replacing HP 7580 all in one scanner fax with HP 7590 all in one scanner fax. I did not have install CD for 7590 so downloaded drivers from HP site. Error message keeps saying that does not recognize...
first Step - Try another USB Cable.. If this does not solve, try the steps below.
Power off the Printer
Disconnect the USB Cable from Printer to PC ( from PC )
Disconnect the power cord of printer frmo wall outlet
Power off the PC
Disconnect the Power cable from back of PC and from wall outlet as well
wait for 10 minutes
Connect the PC power cables to PC and Turn on the PC
When you login to your Desktop, Turn on the Printer
Connect the Cable,
It should get recognised.
Regards,
Ron
Feb 22, 2011 | HP Computers & Internet
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
HP office jet 7310 all in one. when trying to fax it says scanner failure. Turn off power and restart. This accomplishes nothing. Suggestions?
This means that there is an internal failure of some kind (e.g. the scanner is stuck). Be sure that the shipping lock has been removed and try again. HP is very good about support, try contacting them through their website or by phone.
Good Luck!
Feb 05, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I need scheme for scanjet 6100c power supply or complete service manual
it would be cheaper if you just replace it with a 35.00 dollar one it does the same or better your waisting your time but if your learning electronics right on!
Sep 02, 2009 | HP ScanJet 6100C Flatbed Scanner
Suddenly lost driver from menu
check the links below and download the driver for free:
http://driverscollection.com/?H=ScanJet%206100c&By=HP
http://download.cnet.com/Hewlett-Packard-ScanJet-6100C-of-4c-3c/3000-2118_4-70719.html
Have a great day!
Jul 14, 2009 | HP ScanJet 6100C Flatbed Scanner
After running full system recovery I tried to reinstall my printer and scanner. I reinstalled my printer (HP Deskjet 870ces). Then tried to reinstall HP Scanjet 5100c on a machine running Windows XP Pro....
Some time printers and scanners conflict. Try this, uninstall both printer and the scanner, then install the scanner first and try it to see if it works. Then install your printer. If it doesn't work let me know I'll walk you through. Good luck :)
Feb 21, 2009 | HP Office Equipment & Supplies
Series 6100c all in one printer software won't load onto my new Vista computer..worked fine with XP. Thanks. Kim
Are you sure it the 6100c. This appears to be the code for a scanner.
It's almost certainely a problem with the Driver. Try getting the driver specific for Vista from the HP Website.
Good luck
Aug 29, 2008 | HP Office Equipment & Supplies
HP 7140xi scanner failure error
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For further information contact HP chat support, its free of cost.
CLick on the web link to chat with HP technician.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Oct 13, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,107 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
