Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Spilled the oil out of the green tube. phillips magnavox, not sure what size. It leaked all over the boards, plugged it in later, and it shorted out.
Shorted out, now what can I do?
    Genius:
  • 1,030 Answers
GLYCOL...Bad. depending on how bad of spill.. why did spill? crt cracked? stuff very hard to get off boards..
Posted on Dec 10, 2007
I did the same thing with my phillips... blew the board off with carbuerator cleaner, and filled the tube back up with mineral oil...
the oil is simply used to cool the guns...
Posted on Mar 09, 2008
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
Cause of oil in sparkplug tube?
1.your valve cover's spark plug chamber seal is leaking. Which requires removing the valve covers and replacing the gaskets and seals. 2. Excessive oil spills on to the valve cover and ignition coils when adding oil.
**This excess oil on the plug boots can cause the coils to short and eventually fail.
Apr 20, 2010 | 2001 Lincoln LS
Green screen, white lines. Audio fine.
You most likely have a bad picture tube. Green gun is shorted. Usually a set this size is not economically feasible to put a new tube in. You may also have a green drive problem on the CRT board. Have a shop check it out for you before junking it. Thanks for using fixya.
Dec 05, 2009 | Philips Televison & Video
Changing oil, in guns RED Green Blue ( algae)
you can get the coolant kit which has the coolant for all three tubes and step by step instructions on how to do the proceedure on the phillips / Magnavox rear projection Tvs.Heres the link shipping is free within the US.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 22, 2009 | Televison & Video
Will not turn on.
No power - pop the back and check the fuse. Remember to unplug it from the wall first.
Also, look on the circuit boards for spilled fluid. Since you moved the set a bunch the tubes may have leaked. If they leaked on the circuit board it may be shorted out.
Jan 30, 2009 | Philips Magnavox 9P6034C 60" Rear...
Projection oil spill on main circuit board
The coolant in the CRT's is made up of 70% ethylene glycol and 30% glycerin. The coolant is highly conductive and somewhat corrosive. Since you already tried to turn it on im not sure but hopefully you wiped it up first. Take some 100% denatured alcohol and use that to clean the spill you can just pour it on and wipe it off with the set unplugged of course. then let the remainder on the board evaporate (It evaporates very quickly when open) and repeat the process. if your lucky and it did short the first time you turned it on the fuse just blew.
Jan 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
No pic. or sound but power light is on
Most likely the blue picture tube arched and shorted out the horzontal output transistor.Very common problem with this chassis.Now if you have an electronics background you can most likley fix it, if not you will be dealing with finding a high voltage leak consisting of 31,000 volts which can kill you.That pop you heard was the high voltage leaking to ground.
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
OIL IN SPARKPLUG TUBE
Sounds like one of two things. One is it has had oil spilled while adding oil and it has ran down into the chamber by gravity. The other is a leaking valve cover gasket.
Nov 06, 2008 | 2002 Chrysler 300M
Magnavox tv problem a green vertcal streak on rt side
Dickson do you have a speaker next to your tv anything magnet will change color it may need demagnatised
Maxol your tv more then likely has a bad picture tube or you have a shorted transistor for green output shorted on CRT board.
ThankYou for using FixYa. Have a Nice Day.
Dec 28, 2007 | Philips Magnavox 27MS343S 27" TV
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
259 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
