Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Constant message of alignment failure. Black and yellow only printing. Purchased 9-7-09
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
"alignment failed" message. Prints
First, try power cycling the printer (Turn it off, wait 5 sec, turn it on). If this does not resolve the issue, try removing the cartridges and reinserting them carefully.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My printer will simply not print
Sorry about that, but hardware failure is the likely culprit. It is time to replace that printer. There are several nice all-in-ones for about 80 bucks, and some printers can be purchased from Salvation army or goodwill, and all they NEED is a new cartridge, and possibly a USB or Parallel cable.
Oct 01, 2009 | HP Business Inkjet 1100d Printer
Alignment failure
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Thanks, PREM
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
Nov 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Cartridge Aligment Failure
Then printer successfully printed alligment page you must to put this list on scanner glass to confimation and calibration of printing heads and press "Start or OK", without this part of procedure yours printer will be show error message.
Aug 29, 2008 | HP 190 Copier
HP OfficeJet K80 All-In-One Problem: Constant Request To Realign Cartridge
This could be a hit or miss but what does it hurt to try...
I had this problem with the color cartridge a while back. Worked tirelessly with HP support and somehow got it to work. Since it was on the phone and a while back, I fogot! Now is the time for the black cartridge. Same thing. Reading somewhere here about skipping the test I gave it a try and it worked.
- Unplug the printer for 1 minute (not sure if this is necessary but it doesn't hurt).
- Replug.
- When the "Press Enter to align..." message comes up, PRESS and HOLD Enter.
- While holding Enter, press Menu. The screen skips the test part and shows the date.
- Release Enter. Now you can print. Actually, I could print, you are on your own now.
Aug 18, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
HP L7580 Printer Head Problem??
I had the same problem plus had problems with message indicating "alignment failed" and to monitor the blakc/yellow print head.  The print quality was very bad in black.  It seemed to print about 1.5 lines and then skip a line. When I replaced black and yellow it seemed to get better print quality was just as bad.  Finally called HP support. These are the steps they told me to do.
1. disconnect power
2. remove all ink cartridges
3. remove and clean contacts of both print heads
4. perform simultaneously the following press 6 and # on the keypad while at the same time plug in the power.
5.  --- the printer came on (black squares on the screen) and then shut off.
6. --- was told to power up the printer
7. Printer began checking device(took a long time)
8. Printer began aligning printer (took a long time)
9. Finally finished = Message on screen "Alignment Failed"
10. Still not printing and hours later.
11. They will be replacing printer
12. Then they hit you with that you should buy a set of inkjet cartidges from them at $109.96 -  warranty 2yr, works better, etc.
13. Sent to somebody else to arrange shipping new printer.
14. Free shipping 5-7 days - big deal -  placed my work (home office) on hold.
16.  Service help - listen when it follows the script, otherwise like talking to a door  (In India).
17. Finally get transfered to somebody else and he informs me that he is not authorize to give me a new printer, need to talk to somebody else who is not there.  Advises to call during business hours.  He said that he could request that I be called back but that it could take a 1.5 days to get back to me.
18. I am going to call tomorrow morning during business hours - wish me luck.
I don't know what is awaiting but IN The Future I will not talk to anybody from INDIA - they do not have authority and do not listen (but maybe they don't listen because they can't do anything about it).
Good Luck!!
Oct 03, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
629 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
