Question about Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher has water on the bottom that wont drain. I poured some Draino on the bottom but it didn't work. So I tried to run it (without dishes in it) and bubbles and water came out onto my kitchen floor. What should I do now?
  • 63 Answers
**** out the water with a wet vacuum machine. Remove the sump guard and check with you fingers for any obstacles that prevent the draining. **** out the water and anything else from there. Put the guards back.
Posted on Sep 09, 2009
Clogged Bosch SHU 9920 dishwasher
-Sounds like the pump is not working properly or the drain line you connect to sink directly instead to the breath cap before to the sink. Or the breath cap locate too low.
-Make sure the breath cap is mount higher than the line to the sink. (Or as high as possible) This is to prevent any water from the sink pour into the dishwasher.
Good luck
Mai
Jun 16, 2017 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Kenmore Quiet Guard is clogged on the bottom. Leaking water.
take out the bottom rack, pop out the center. use a snake on the drain. if not aviable us a wirer coat hanger. the water should go down. to top it off ad some draino or something like that. but rises your dishes before you put it in the dishwasher. remember a dishwasher is not a garbage disposal. run the dishwasher again i wish nothing in it. that will flush out the drain. then your good.
Jan 02, 2013 | Dishwashers
My dishwasher does not drain. Can I use drano?
No, I would not advise using Draino in a dishwasher...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 | Dishwashers
Dishwasher will not drain already checked screen and hoses
if you have checked the drain in the bottom of the dishwasher and it is clean, then you have a plumbing problem. maybe try pouring some draino down in the dishwasher to clean out the hoses
Jun 28, 2009 | Kenmore 17252 Free-standing Dishwasher
Dishes still dirty
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine.
Apr 03, 2009 | Dishwashers
GE Triton XL, Dishwasher, while washing dishes in the sink
Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
Jan 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher problems
First thing to check water hose that connect at back of machine. pull the screen out and clean it. use a pliers. I run my under water then use a q-tip if its clog to clean the rest.
Then pour a cup of vingar in machine and run it.
Oct 04, 2007 | Danby 22 in. DDW396 Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
127 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
