Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
Oil plug blew off top of metal housing during use
My son (in another part of town) was using my Troy Bilt pressure washer - 3000 psi - 7 HP, for a while and noticed at one point that oil was spewing out of a threaded hole on the top metal casing, not the oil fill or drain holes.
Apparently it blew off the cap that seals this threaded hole.
I had just changed the oil and felt that I had not overfilled.
Any ideas why this happened?
  • firehead May 11, 2010
    Is this the oil fr the engine or for the pump?
    President:
  • 583 Answers
The only times Ihave seen this happen is when the pump seals were on the way out and water is pressurising the pump.the other thing that comes to mind ,you said you had just changed the oil , did you use non foaming oil? if not theoil will expand as it aereates but then it cenrerally looks milky but is does come out the breather etc
Posted on Sep 10, 2009
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
323 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
