Question about Samsung HCM4215W 42" Rear Projection Television
I have no pitcher and no sound found the 250 amp
I have no pitcher and no sound found the 250 amp fuse is blowed and one i c is burned up (1c851) looking for refurbish board or new one
  • Samsung Master
  • 5,138 Answers
Replace the whole board will have number on it ,call Encompass Electronics 1-800638-3328 or go to there website www.VanceBaldwin.com
Posted on Sep 19, 2009
Toshiba 37E200U LCD television
T5.0AH 250V used in this TV is a ceramic fuse Time delayed (Slow-Blow) and the dimensions are probably: 5 mm (3/16 in) x 20 mm (3/4 in). You just measure the old one.
Regards GJ
Jun 20, 2014 | Toshiba 37E200U 37 in TV
Emerson LC320EM2 no power, no sound, blows the 4 amp fuse on the inverter board
this is a combo power inverter board there are several parts to replace , one is the main transistor and check the rectifier diodes along with your brain for buying an emerson
Sep 04, 2013 | Emerson 32in Class LED-LCD 720p 60Hz LED...
Need fuses for janome 4000
You can get the fuse at Radio Shack. Part number 270-1065. It is a 3.15 amp 250 volt slow-blow fuse.
If you replace the fuse and it blows again, you need a new A circuit board part number 829606005.
Nov 03, 2010 | Janome Memory Craft 4000 Sewing Machine
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
My jbl pb 10 has a noise and it burn the fuse... changing the fuse it burn the fuse again..so it might have som other defective part that is causin the noise and the fuse burning... any sugestion?
It blows the fuse because a semiconductor device has developed a short (in otherwords acting like it was just a piece of wire). Because of the noise I would suspect the main amp device is the cause. It will be most likely on a heatsink.
Feb 06, 2010 | JBL PB10 Subwoofer
Blown fuse in Subwoofer unit, what amperage to
usually it is 0.5 amps. if it still blows, you might have a shorted board.
Nov 25, 2009 | Logitech X-530 5.1 Channel Speaker System...
The unit won't power on at all.
You can try replacing it with any 10 amp fuse just to see what happens. If a new fuse keeps blowing out then you have a shorted power amplifier inside(they consist of transistor or a single chip). These device look normal most of the time short out with any visual indication. If you desolder the power amp chips(they are mounted against an aluminum heat sink to dissipate heat) and the fuse quit blowing then it is the problem.
Aug 11, 2009 | Samsung HT-TX72 Theater System
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Pioneersd533hd5
Had the exact problem on 11/14/06. Ordered a power supply board, which was $300+, got it in and when I went to replace the part, found that the old part had a blown fuse (a lot cheaper). Of course if I had put in the new part it would have fixed it also. CHECK THE FUSES IN THE MIDDLE CIRCUIT BOARD (there are 3 boards).
Nov 10, 2006 | Pioneer SD-533HD5 53" Rear Projection HDTV
Samsung HCM4215W 42" Rear Projection Television Logo
81 people viewed this question
Jerry Greenberg
Jerry Greenberg
