Question about Panasonic PT-56LCZ70 56" HDTV
Our Projection tv does not turn and is flashing
Lamp lite flashing red
    Problem Solver:
  • 10 Answers
If this is a DLP (digital light projection) ? If so, the lamp is probably out. DLP's are infamous for lamp failures. You can replace that yourself if you can find someone to order it from. Look it up online or check with a local repair shop. The only thing to be careful with is when you self diagnose a TV and maybe something else in the TV is causing the lamp to go out, you may find a new bulb goes out shortly after you put it in. So... it's best to have a certified technician diagnose the TV to make sure it's not "just" the bulb.
Hope this helps!
Posted on Sep 09, 2009
Sony wega/60 inch would not turn on,is it the lamp or some thing else.
The tv LED light "LAMP" indicator flashes or lite up?Tv Projection lamp been inside this tv like about 2 years already,tv on and in used everyday like 4 or 5 hrs daily?Yes,than the tv projection lamp life are ended and require tv projection lamp replacement.
Jun 15, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
It shutts off ramdomly the red lite blikes an have to what for green light to come on before it turns back on
Tv "LAMP" LED lite indication flashes or staying on?The tv projection lamp life is over.The projection lamp require changing.
Aug 06, 2010 | Panasonic PT-50LC14 50" Rear Projection...
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Sonny tv-kds-50a2020
you need a new lamp sorry
shaun
Mar 27, 2009 | Sony KDS-50A2020 Television
I have a 56" rear projection panasonic tv when i turn it on green lite come on then a lamp lite comes on red no picture or sound lamp lite flashing
Doulbe check in the owner's manual, but this is usually an indication of a bad lamp or fan error. There will be a table in the owner's manual listing the error codes as shown by these lights. I can't give you more details without the exact model number.
hope this helps,
Dan
Sep 08, 2008 | Televison & Video
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-56LCZ70 56" HDTV Logo
304 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
