Question about HP LaserJet 1200 Printer
Hp 1209 all in one has clogged print nozzles only prints color not black
Yellewo does not print
Must replace the nozzle/ cartridge carriage as the nozzle for yellow is most likely clogged
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Aug 31, 2014 | HP LaserJet 2840 All-In-One Printer
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
I can't correctly print color and black at the same time.
check it property setting for cattradge selection in setting
Jun 06, 2013 | HP PSC 1209 All-in-One InkJet Printer
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Dear Adrienne,First make sure that the black ink is not empty. If you are sure the black ink is full enough you need to check the print head condition. The print head may be clogged or faulty.
To fix the clogged print head,please perform the following step:
  • Print the nozzle check pattern, access the following menu on LCD: Menu>Maintenance>Nozzle Check. The good nozzle pattern should like below sample image.
  • If the print head nozzle missing some color (i.e Black) the perform print head cleaning: Menu>Maintenance>Cleaning. Then print the nozzle check pattern again. Note: you may repeat this step up to 3 times.
  • If the problem still remain,then you should perform Deep Cleaning: Menu>Maintenance>Deep Cleaning.
If you have perform the above steps but the problem still the same,please check whether the black nozzle missing partially or totally. The faulty Purge Unit (ink pump) may cause the same problem. I mean the purge unit does not work properly so the ink cannot flow. Good luck :)
Regards,Xanda
Oct 05, 2011 | Office Equipment & Supplies
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
It won't print in black. We have tried 3 differant cartridges. At times it prints a shasding of the image. All the other colors work fine.
Use the HP Printing Assistant software to run a few "print-head-cleaning-cycles".
The BLACK ink-jets are CLOGGED. So, no ink from any of the 3 different cartridges reaches the paper.
Mar 15, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
When you change the print heads for a Hp L7580 what problems does it resolve?
Replacing the print heads fixes any poor print quality you are experiencing. Typically people replace print heads when a certain color (most likely black) is printing very faint or streaky. Over time the nozzles in the print head can get clogged with dried up ink. Enough clogged nozzles will inhibit ink from being deposited on the page in certain areas.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Will print only color. will not print black with a
First print a test page to make sure the printer's firmware is working correctly. See here. Check here to see that you have the most current driver installed for your OS.
Then use this article to set the print properties to print in grayscale using the black ink cartridge only, and test the printing.
If you get no output from the black cartridge, see this article or this article for help with cleaning and checking the cartridge contacts. Make sure the tape is removed from the cartridge nozzle. You may try running the auto clean utility a couple of times, but be aware that this consumes ink, and if you are not getting black printout, it's likely that the print nozzles are clogged with old ink. Sometimes even a new cartridge can be out of date, or have been stored incorrectly, and cause this.
I've read of cases where people were able to use a vacuum nozzle to clear clogged cartridge nozzles and get them operating again, but haven't tried this myself, and recommend if you do you attempt it in an environment where ink can be cleaned up. (See here for more on that.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 28, 2009 | HP DeskJet 5150 InkJet Printer
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
HP LaserJet 1200 Printer Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
