Question about Dell Dimension 8250 PC Desktop
Unable to open DVD drawer
Unable to open DVD/CD Rom drawer
  • Steve Green May 11, 2010
    Does it try to open (make noise) and quit?
    Novelist:
  • 110 Answers
If you take a paper clip and straighten it, there is a little hole in the front of the CD drive, push the paper clip into it and your CD drive will get pushed open. This will get a CD out, but will not fix it.
Try re-seating, or connecting a different power cable to the back of the CD drive. Does your PC even recognize that the CD drive is present?
Most of the time the CD drive needs to be replaced.... they are very cheap.
Posted on Sep 09, 2009
Testimonial: "works like a charm took one try-now it opens every time. Thanks"
  • 21 Answers
Look exactly on the front panel,ther is a small hole to open. use something to put inside and push, tray should be had to leave.
Cd is stuck in my gateway computer
If you open Computer in the Start Menu, right click on the DVD/CD Rom, select Eject , it still will not open? Look for a "pin-hole" on the DVD/CD drawer, near the button, insert a pager clip. If the CD has exploded, which happened to me, you will have to remove the DVD/CD Rom and dissemble it.
Mar 07, 2013 | Computers & Internet
Dvd drive won't open
you can try opening it with paperclip if it's stuck. Straighten the clip and locate a small pinhole on the drive it and insert the clip in. You might need to push the paperclip in an out a few times to eject the drawer.
Jun 19, 2010 | Computers & Internet
My cd draw is stuck in the cd drive. How do i get it open
you should find a paperclip and straighten it out, on the front of the CD drive there will be a small hole just big enough for the straightened paperclip to fit in. Push it in until you feel tension and it should start to manually open.
Sep 12, 2009 | Dell Inspiron 6400 Notebook
Sony combo dvd rom dont open dvd
check your lense with deffferent dvds if it works then it is ok if it not works then you have change or repair lense if it is warrenty take it to service shop they replaced it.
Jul 13, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
CD Rom drawers do not open or close, drive belts have popped out
Unfortunatly, these belts are not availible for consumer purchase and, most service centers will just replace the entire device. i have used regular rubber bands that are identical in size to run many rom drives. this method seems to work just fine.
Its very unfortunate when these original belts break and, there is no replacment belt on the market. the only option is to purchae a store bought rubber band that matches the same size as the broken original band. this will work.
Jun 10, 2009 | Dell Dimension 8400 PC Desktop
Hmmm... my cd rom driver is not working well. i cannot open and play a cd. i dont know how to fix my aplication. how can i fix my problem?
Should be a tiny hole in the front just below the cd drawer (make sure its not the indicator light hole)
Insert a paper clip or thin piece of wire (about the same diameter as the hole) into this hole and you should feel a solid piece maybe 1/2 to 3/4 inch in. Push firmly on the wire and the cd cdrawer should open out a bit. Gently pull it further and remove the cd.
Reboot your pc with the drawer left out - it should close by itself - if it closes OK then try opening it with the front button. If that works try another cd in it. ANy drams with get just get a new dvd/cd player or burner as the cd player is not worth repairing or replacing due to the cheap cost of dvd player/burners.
If it closes ok then try opening it with the button -
Jan 05, 2009 | Samsung Int. IDE CD-ROM 52x Beige Bulk...
Internal CD ROM will Not Open
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Dec 31, 2008 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Dvd/cd problems
Open the dvd/cd rom & manualy clean the lense, now check the Rom if again not function then change it, there is no option other.
Mar 08, 2008 | Computers & Internet
DVD/CD ROM problem (Dimension 5150)
you cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Jan 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 8250 PC Desktop Logo
165 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
