How is it possible to remove the hard drive with minimum screw removal?
  • cbbrhje Sep 09, 2009
    Presario 2100 by Compaq. Windows XP(Home) has a corrupted file and attempts to repair have failed so plan is to pull the HD and salvage all files. TY!
  • 596 Answers
What type of notebook do you have. Thanks
C2Solutions
Posted on Sep 09, 2009
  • Nouveau IT, LLC
    Nouveau IT, LLC Sep 09, 2009
    Thanks for the reply. Turn your pc over, Near the front you will see the hard drive door with 2 or 3 rubber feet close by. (center of your notebook.)
    Remove the rubber covers
    Remove the screws - 2 or 3 2.5mmx6.0mm screws
    Pull the hard drive out of the notebook.
    To install just reverse the processo.
    Good Luck
    C2Solutions
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
Remove a hard drive
Depending upon your model laptop, the hard drive may be located behind a panel on the bottom of the laptop or it may be located on the side of the laptop and the retaining screw/s will be on the bottom of the laptop.
When you remove the panel the hard drive will be screwed to a hard drive caddy. Remove the screws on the caddy to release the hard drive. Keep these screws as you will need them to fix the hard drive to the caddy.
Feb 11, 2012 | Sony Computers & Internet
How do i remove a harddrive from a computer case when only one side has screws to remove? Details: Okay so i'm trying to remove a hard drive from a computer case that only has screws on the back right...
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
Jun 12, 2011 | Compaq Computers & Internet
Where is the location & how to remove the hard drive for toshiba satelite P15-S470
The hard drive is located under the CD/DVD drive. Before you start taking apart the laptop, remove the battery and unplug the AC power.
1. You have to remove the CD/DVD drive. Turn the laptop over. Remove one screw right above the dive and slide the drive out of the laptop.
2. When the CD/DVD drive is removed, you'll see a metal plate. The metal plate is secured by 4 screws. Remove them and lift up the plate from the bay. The hard drive is located right under the plate.
3. After you remove the plate, you'll see the hard drive. The hard drive also secured by 4 screws. Remove the screws, slide the hard dire to disconnect it from the connector on the moterboard and lift it up.
4. You have to transfer the brackets from the old hard drive to a new hard drive. Also, if there is a foil shielding around the old hard drive, you'll have to transfer it to a new hard drive too.
Below is website with a picture guide on how to remove the hard drive>>>>
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Regards.
Apr 21, 2011 | Toshiba Satellite P15-S470...
Remove hd compaq presario 1621
I think it is the same as HP. When you undo the cover just pull it right out by the small plastic. No screws holding the drive.
Apr 21, 2010 | Compaq Presario Notebook
How do you take the hard drive out of a dell latitude cpx J650GT
on the bottom of the laptop there should be four screws un screw those and take the cover off next take the keyboard and top covering off then carfully remove the hard drive which should be loacted near one of the fans.
Nov 26, 2008 | Dell Latitude CPX-J Notebook
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Nov 03, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
How do I remove the hdd from compaq nx9010?
Hi - follow these steps and picture:
. Remove the hard drive by following these steps:
a. Remove the two rubber screw covers 1 that conceal the
hard drive retention screws.
✎Spare part number 371808-001 should be used to replace
the hard drive rubber screw covers.
b. Remove the two PM2.0×6.0 screws 2 that secure the
hard drive to the notebook.
c. Use the notch in the hard drive bezel to slide the hard
drive forward 3.
d. Remove the hard drive.
864136d.gif If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 21, 2008 | HP Compaq Business Notebook NX9010
Remove hard drive
Did you remove screws from both sides of the hard drive?
Jan 13, 2008 | HP Pavilion 9695C PC Desktop
Hard drive removal
  1. Loosen the two Phillips-head screws that secure the hard drive cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the inside edge of the hard drive cover and remove it.
  3. Loosen the spring-loaded Phillips-head screw that secures the hard drive.
  4. Hold the Mylar tab and pull the hard drive toward the outside edge of the base enclosure to disconnect the hard drive from the system board connector.
  5. Lift the hard drive out of the bay and remove.
  6. Place the hard drive in a static dissipative bag.
Replace the hard drive
  1. Remove the hard drive from the static dissipative bag.
  2. Place the hard drive into the hard drive bay.
  3. Push the hard drive toward the inside of the base enclosure until the connector is seated.
  4. Tighten the spring-loaded Phillips-head screw that secures the hard drive.
  5. Insert the hard drive cover into the enclosure.
  6. Tighten the two Phillips-head screws.
Nov 16, 2007 | HP Pavilion Ze4805us Notebook
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
