Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Adjusta ice cube maker not working
Just hooked up water line to ref. and turned on ice maker and it doesnt work
  • 25 Answers
Have you checked if water is comming out the tubing before hookup? A valve may be close...
Posted on Dec 10, 2007
The ice maker is not making ice is it is in a kenmore ref. it appears that there is nowater in the ice mker
Is there a water line connected to the icemaker? Is it turned on? If there is no water in the icemaker and if the water line is hooked up and turned on, then you've got a parts problem and should call Sears.
Jul 28, 2017 | Kenmore Refrigerators
Ice maker has stopped making ice
most likely a bad water inlet valve located in the back of the ref where the water line hooks up at
Nov 18, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
New refrigator with plastic tube for the ice maker
there must be a solenoid some where on the line to control the water.
if the solenoid is present home depot hsa a kit with instructions to hook it up
Jun 27, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
U-line ice maker BI-95
hi,
try to steady your thermostat setting to the lowest or not turned at all. more stock in your ref. can help your ice maker not to frozen. if you have less stock in your ref. put some gallons of water. or put your ref near the fire bin but not too close. or with a circulation of hot air
Sep 19, 2008 | U-Line Refrigerator Ice Maker
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
616 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
