Question about HP Office Equipment & Supplies
The printer will not print from the computer , it makes copies fine and the fax works but all of a sudden the printer will not print
  • 21 Answers
1. Disconnect the USB cable from the computer, remove the printer and drivers. first start and only install software when the installation program asks you to plug it in to connect the printer.
2. If you check the printer by connecting to another computer, and If both computers will not install or printer will not be recognized by the computer, contact your service, the problem may be damaged electronics,
Posted on Sep 09, 2009
HP Office Jet 7410 printer copies, fax are black
If you make a copy and it is black, either the ccd (reader is bad or the lamp is out) either is the end. Take it back to staples if you can.
Make sure you unplug it for about 1 hour and plug back in and try a copy.
Apr 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Can't fax out on my Epson Stylus CX5800X
Verizon is lying to you. Fax machines are analog devices.
Mar 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Jan 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Fax Machine Samsung Model SCX-4521F
Kindly update me Is it printing/Copying working properly.
This issue with printing part. Kindly clear memory. Check Cartridges.
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Will not copy
plz try by printing from the computer, if the problem persists then your device needs servicing
Aug 14, 2008 | Office Equipment & Supplies
Printer and Making Copies does not work!
Will the machine run a paper path test?
This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
Nov 26, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
