Question about Dell UltraSharp 1707FP Monitor
Power button damange ,
Dell 1707FP Flat Panel the power button is damange,how can open the monitor to fix the button
I used two thin putty knives this morning to open the monitor case. First, unscrew the four screws at the back. Then insert a putty knife into the small crack between the front bezel and the monitor shell. Carefully work you way around and wiggle the putty knives. Note that the front buttons are attached to the thin black edge at the front, and there's a thin cable at the bottom. Don't damage that. You can take off the back shell though.
Posted on Feb 23, 2010
How to fix my Dell 1707fp monitor screen goes black after a few seconds when turn power on?
could be what they call the inverter and that is behind the screen at the bottom.
Nov 03, 2016 | Dell Computers & Internet
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
It is a Dell monitor, Model 1707FP. The screen went black and the power button is blinking. It does not make a difference whether I disconnect the video cable or connect it to another computer. What are...
http://s807.photobucket.com/albums/yy352/budm/Dell%201707FP%20Rev%20A01/
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Aug 12, 2010 | Dell UltraSharp 1707FP 17" LCD Monitor
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Can't power on my DELL 1707FP monitor
Try a different wall outlet. If no go swap the monitor and tower power cables. I still no joy disconnect the power cord from the monitor, hold the power button for 10 seconds with the power cord disconnected. Try Plugin intu cable. If the screen is still dead check with dell tech support if the monitor has a warranty active on it. If the warranty is out get the monitor checked at a local computer shop.
Aug 08, 2009 | Apple Power Mac G5
1707FP MONITOR WON'T TURN ON. CHECKED ALL POWER SUPPLY, ALL OK. ON BUTTON WON'T DEPRESS
Generally this doesn't happen with Dell, I f you arn't using DLC or UPS there are chances of circuit break down in the display unit.
Jul 02, 2009 | Dell 1707FPv Monitor
Power on/off button not working on Dell 17 in. Ultrasharp 1707FP
hi. probably de botton is damage or broken. if you have experience opening electronic devices like monitor you can replace that button you can purchase online. depending on the type of button, you can see a full tipe of button here: https://www.sparkfun.com/categories/145?page=all
Sep 16, 2017 | Dell UltraSharp 1707FP Monitor
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell UltraSharp 1707FP  Monitor Logo
468 people viewed this question
Alun Cox
