Question about Office Depot Ativa LH-1H18AX DVD±RW Burner
It says my drivers are missing or deleted and wont work properly without them where can I find them again?
  • wayin2002
    wayin2002 May 11, 2010
    Please clarify where it is saying this. Yo may also wish to look at www.driverguide.com
    Novelist:
  • 142 Answers
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK.
  4. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  5. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  6. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  7. On the Edit menu, click Delete.
  8. When you are prompted to confirm the deletion, click Yes.
  9. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  10. On the Edit menu, click Delete.
  11. When you are prompted to confirm the deletion, click Yes.
  12. Exit Registry Editor.
  13. Restart the computer
Posted on Sep 10, 2009
IN MY PC NO USB AND LPT PORT DETECT
This can be caused by adding and removing devices without releasing them properly. It can damage devices as well as USB ports etc. Download the drivers again or go in to device manager and select delete USB ports power down and restart the machine again. It should pick up the ports again. John
Apr 19, 2012 | Computers & Internet
AIPTEK Dv8800 Driver malfunction? Answer
  1. aiptek web site has a driver solution for vista users I had same problem but with Win XP it keep seeing it as a flash drive .... I uninstalled drivers and re-installed them,- same error, then uninstalled again and removed the USB from device manager uninstalled direct X cause it was the newest version, then install everything from scratch without turning the camera on then try again and nothing, finally I turn to the manual and somewhere says "if you need to use it as web cam then press the menu button on the camera and select camara!!! as soon as I did that and additional port found in windows was detected and installed automatically then I got my video and microfono up and running. So easy right, but like always the software CD is missing the manuals too and people do not read. LOL .....
Jan 15, 2010 | Aiptek DV8800 Digital Camera
Wacom Tablet Installation: Where's the Setup Process?
What you should do now is to go to Control Panel->Add Remove programs. Select the entry for this tablet and delete it. after disconnecting the tablet reboot the PC. Then without connecting the tablet, install the drivers, Reboot. Connect the tablet and allow Windows to detect the tablet and load its drivers. Then only will work properly.
Nov 19, 2009 | Wacom Graphire3 Tablet 6x8 (C267252627)
How to replace missing cmicnfg.cpl file
This error occurs after trying to uninstall the updated (and overrated) C-Media WDM Audio Driver for onboard sound that appears after upgrading to XP SP2 and/or going to WindowsUpdate. Likely the driver didn't work, so you tried uninstalling the driver and were going to put back the old Realtek AC'97 driver, but couldn't get rid of the updated driver.
To fix: Start, Run, type in "regedit" (no quotes), and delete the cmaudio string from
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run. This makes it so it will not run on startup and try to find the cpl file that was deleted during the uninstall or not installed correctly by the installer in the first place, whichever your case depending on when you started seeing the error. If your sound was working perfectly before this, you are done. To get your sound working again if it isn't, read on -
While still in the registry editor, click on the top computer icon in the Registry Editor to highlight it (so that it will do a complete search of the registry and not just from your present point forward), do a Find (Ctrl+F) and find and delete all KEYS related to cmaudio and C-Media, not just the string entries, but the KEYS, except for that entry in the Run key I mentioned above, just delete the cmaudio string for that one.
Delete the string "CMCPlus" from HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Control Panel\Cpls to get rid of the Control Panel icon, and delete the file it points to that resides in C:\Windows\System32.
Download this remove utility from
http://ekiis.com/Freesoft/binary/remove11.zip
and run the file you find in the zip file - it can be ran without extracting it from the zip. Take out the C-Media Audio Driver line.
-- NOTE: This utility is for taking the name out of the Add/Remove Programs section only, and does not remove it from your computer, but it is very useful for issues like this when we are MANUALLY uninstalling a program to take it out of the Programs list and should work in 98/ME/2000/XP.
Delete these files from the C:\Windows\System32 directory (or "System" directory for Win98)
cmirmdrv.exe
cmirmdrv.dll
cmuda.dll
Delete everything you can readily delete in C:\Temp, C:\WINDOWS\prefetch (XP only), C:\WINDOWS\Temp, and C:\Documents and Settings\%YourName%\Local Settings\Temp (2000 and XP only), so that there will not be any files left for it to try to recover the driver from. You will likely have to leave things that start with hsperfdata_ and Perflib_Perfdata_***.dat files if you find them, but should be able to delete most others without changing attributes.
Now open the Device Manager (Right-click "My Computer", hit "Manage", then find Device Manager in the Computer Management console). Right-click the C-Media WDM driver under Sound, video, and game controllers, hit Uninstall. Then right-click the top computer icon listed there with your hostname beside it, hit "Scan for hardware changes". It should install a generic "Multimedia Audio Controller" instead of the "C-Media WDM Audio Driver", though you might see that C-Media Audio for just an instant before it reverts back to a generic driver (if it stays, you'll have to go back through the registry again, delete the system files again, and do a full search of your hard drive for those files so they don't get re-copied again). From here you can download your specific Realtek AC'97 Audio Driver setup.exe file here or use your motherboard's installation CD to re-install and you should have sound again.
good luck!!
pls feel free to visit my blog http://manual4users.blogspot.com
thankz!
Oct 07, 2009 | Computers & Internet
Dell 922 printer
Clean the driver wheels with an eraser
Sep 18, 2008 | Dell 922 All-In-One InkJet Printer
Office Depot Ativa LH-1H18AX DVD±RW Burner Logo
298 people viewed this question
Top Office Depot Computers & Internet Experts
k24674
Vernon Taylor
Are you an Office Depot Computer and Internet Expert? Answer questions, earn points and help others
