Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My stove is not allowing to bake. The broil works
My stove is not allowing to bake. The broil works and the stove top works. I don't see any glow from where it is suppose to light at.
    President:
  • 704 Answers
It would appear that the electric ignitor isn't functioning as it should and might need to be replaced.
You can remove the oven racks and the bottom oven floor to observe the ignitor. now turn the oven on and see if the ignitor glows, if not, the ignitor is faulty and needs to be replaced.
You can enter in your full model number at the following site and get the replacement part number (and price). If you're going to do the repair yourself, be sure to turn off the power or unplug the range from the power outlet before doing any work on it.
You'll need to pull the oven out so you can get at the backside panel where the electrical connections are located. There is also a screw on the inside of the oven that holds the lower iginitor in place. Simply remove and replace the faulty one with the new one and you should be fine.
If you want to confirm that the ignitor is the only issue, you can swap out the broiler ignitor with the oven (lower) ignitor, as they should be the same part for your range. If you swap them and the oven doesn't ignite, then the faulty part is probably either thermocouple that tells the gas inlet valve control, which lets gas enter into the oven. The thermocouple which tells the gas valve to open, once the ignitor has reached the proper temperature, so if the thermocouple isn't working, the gas valve won't open.
Here's a link that you can enter in your model number and get the parts list and a line drawing for your range. I think you're missing a few letters or numbers in your model#.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=JGBP90
My bet is on the ignitor as the faulty part, but the swap test will confirm that, and if the swap doesn't work, then the thermocouple is bad.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
I have a G E Spectra gas stove and oven the gas oven doesn't work
does it not bake or broil? if this is the case, it could be the control panel. however if one or the other of the bake and broil functions work then it would most likely be an ignitor. check to see if your broil and bake ignitors glow. to access the bake ignitor you must remove the bottom panel from the oven but you can probaly see it gowing without removing the panel. the broil ignitor should be in plain sight.
May 28, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
My Whirlpool Super Capacity 465 just made a VERY loud pop noise and shot out a blue flame. Knocked the breaker off. reset breaker and stove appears to work ok. Should I continue to use stove?
you most likely had a bake or broil burner short out. the unit may seem to heat but it probably doesnt bake right. look at the elements and see if they have a rough or blistered apperance to them. if so it probably isnt working. you can also check to see if both elements are glowing red when they are on.
try the broil cycle and if its ok then try the bake cycle, my guess is one of them is blown out.
Dec 29, 2008 | Whirlpool GS460 Gas Kitchen Range
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Maytag Gemini gas top oven does not work.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Jul 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
The control panel on my gas range does not work the light clock works the stove works but the bake and broil does not i cant get the oven to start and it is not self cleaning but it has a lock button it...
IF ,WHEN YOU SELECT BAKE ,DOES THE BAKE COIL GLOW RED??????? IF YES IS CORRECT, THAN REPLACE THE BAKE COIL(IGNITER).SAME FOLLOWS FOR BROIL. PLEASE RATE THIS!!!
Jun 06, 2008 | Whirlpool Kitchen Ranges
Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Mar 23, 2008 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
363 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
