Question about Konica Minolta DiMAGE Z6 Digital Camera
Locked card my card is locked and will not let me take pictures. I go into menu and on page 1, delete, format, lock, and edit movie are all grayed out and unaccessibe.
  • 589 Answers
What do you mean "locked"? Did you accidentally slide the "lock" tab on the card itself? Also, these cameras are VERY picky with memory cards. They can cause numerous errors, and cause the camera to shut itself off for no reason.
Posted on Jan 07, 2008
How do i unlock the card on my exilim.casio camera
if you put the camera on view and scroll through them does it give you any options , such as save ,delete etc,etc.
Feb 27, 2015 | Casio Exilim Cameras
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How do I delete pictures from a coolpix S4000
To delete individual pictures: while viewing the picture, tap the trash can icon on the screen, then tap yes when it asks for confirmation.
To delete all pictures on a memory card: format the card. TAP MENU, tap the wrench icon, select "Format card."
To delete all pictures in internal memory: format internal memory. Tap MENU, tap the wrench icon, select "Format memory."
The delete instructions are in the "Deleting Pictures" section of the manual (page 33 in my copy). The format instructions are in the "Format Memory/Format Card" section of the manual (page 150). If you need a manual, you can download one from the manufacturer's web site at
http://support.nikonusa.com/app/answers/detail/a_id/16763
Jul 16, 2011 | Cameras
When trying to clear out my camera... there is a black screen & it'll say this picture cannot be deleted when i try to delete. taking up space that i would like to use
Make sure the picture you can't remove isn't locked. When you're in review press menu and make sure that photo isn't set to locked (if so unlock and you should be able to delete it).
If that doesn't help, make sure you copy off all the images on the card you want, as the following instructions are intended to clear the entire card.
After you transfer all the images you want, you'll want to format the memory card. This can be done one of two ways. If you have the appropriate card reader on your PC, you can insert the card, find it in my computer. Then right click it and select format.
The easier way is to use your camera's format feature. I don't have that specific model, but it can usually either be found in menu, or by pressing the picture review button and then menu. Formatting the card should erase all the data on it and clear off the picture you don't want.
Please leave feedback if this was helpful. Thanks.
Apr 05, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
Samsung TL210 When trying to delete a image in camera recieve a "file error" message and unable to delete.
Check your memory card for the lock. If it's not locked and you steel having the issue then try backup all you pictures and format the memory card using format utility in setup menu.
Mar 13, 2011 | Samsung DualView TL210 Digital Camera
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
Camera says memory card is write protected. How can I delete pictures on the card and take new ones?
write protection lock is turned on,, turn it off this maybe 1. a switch located in the camera 2. on off option in the camera menu else plug the camera to memory card reader to delete or format the chip :)
Dec 15, 2010 | Nikon COOLPIX S51 Digital Camera
Power Shot A630 says card locked, will not take or delete pics
There is a switch on the side of the SD card, slide to unlock position then go to the SETUP menu, format the card (before doing that, make sure you have saved all pictures from the SD card to your computer)
this post may help
http://www.fixya.com/support/t2167722-screen_saying_memory_card_protected
May 08, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Locked photos on card
hey.. do not format ur card! just go to your pictures that u cannot delete and press menu and press playback options then you can see a key open it up to remove the protection on your picture... after that u can now easily delete that picture.. okay...
Feb 04, 2009 | Olympus Stylus 790SW Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
129 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
