Question about Pioneer Car Audio & Video
Used a wiring harness matched all colors but not getting any power on the stereo im installing whn i switched it back to the stock stereo i got power and the stock works fine
Chek the ground some times the diffrent radio need there own ground
Posted on Sep 09, 2009
I have a 95 gmc sierra 2500 and im trying to put in my aftermarket rafio so i cut the stock harness out the square puece that goes in back of stock radio and now i cant figure out what wire is what i got...
I would suggest you spice the wires back to stock harness by male and female connections and tape over them with black tape then get a stereo install kit that includes a wiring harness ( cost about $20 maybe or less) for the year of truck you have... it will plug right to your stock harness ...never just cut stock stereo wires from stock plug it will be more of a headache than you think trust me I've installed all my own stereo system been there done that... good luck
Mar 31, 2015 | 1995 GMC Sierra
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
I need the wiring diagram for a dual stereo model xd1225 to hook it up to a 1986 ford f150
OK, for starters, get a wiring harness made for your vehicle. All aftermarket radios have standardized wiring colors. You wiring harness will have matching colors, so it will be easy to hook up. The harness will also have the diagram of colors on the package. However, you vehicle wire colors will not match this. That's why you have the harness. You will just plug into the stock vehcile harness. You will not have to match any wires because the harness is specifically made to match your vehicle. Trust me, it's easier this way. You can find them all over, try www.crutchfiedl.com to get one if you need. Hopd this helps.
Aug 23, 2011 | Car Audio & Video
IF I HAVE A 98 DODGE NEON AND A DB165 CLARION STEREO HOW DO I MATCH THE WIRING TOGETHER?
Well, this depends on how easily you want the job. If you want it quick and easy, go to ANY best buy, sears, or car audio place and ask them for the appropriate wiring harness. A wiring harness is a pre-wired "Modual" that Links up with your car's current wiring modual. These are a WHOPPING 12-15 dollars. These piddly price can literally save you 1-3 hours of needless work. IF your just bent on saving that 12 bucks... and wanna solder ALL those wires together one by one and do all teh matching, etc, the first place to look would be the wires on the back of the Stereo unit. Most stereo output wires are labled in small print. Then find a manual for your car , year , make and model, and see what the stock wiring is... simply match em up and solder em together.
Feb 27, 2010 | 1998 Dodge Neon
05 grand what do i need to install a aftermarket radio
Get a wiring harness adapter kit (about $10) from a stereo shop. It has harness plugs that will plug directly into your harnesses in the dash, and has color-coded wires that you will color-match to the wires on the aftermarket deck's harness. You may need an antenna adapter as well. If your stock stereo face is taller than the aftermarket one, you'll need a dashboard adapter kit to take up the extra space.
Dec 10, 2009 | 2005 Pontiac Grand Am
1997 kis sephia wire harness
you can get a repair manual at your local parts store it will have your diagram you need !
Aug 08, 2009 | 1997 Kia Sephia
Im trying to find where i can gt a complete guide on how to install a car stereo from color coding the wires to installing a dash kit
  1. DISCONNECT THE NEGATIVE TERMINAL ON YOUR BATTERY!
  2. For an old stock stereo, you may have to remove the dash or certain parts of it to access the stereo. Do that by locating screws and bolts and taking them off. Make sure to keep them in a safe place.
  3. For an aftermarket stereo, insert DIN tools into each slot on the stereo behind the faceplate. Slide the whole stereo out.
  4. Disconnect the antenna wiring (The wire with the big metal tip)and the stereo head unit wiring (wire harness).
  5. Reconnect the antenna into your new stereo.
  6. Use **** connectors and wire crimps to connect the stock wire harness with a car specific one that is sold seperately. The color of the wires on each harnass should match up.
  7. Reconnect the negative terminal on your battery and see if it works.
  8. Slide the stereo back into the dash and remount the dash that you removed, including screws and bolts.
hope this will help you
Jun 05, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
After market stereo install
you will need to get a cord that connects to the sterio and then you need to match them up with these wires
the colors for the radio that are hooked up to the car are
  • orange is power
  • red is egnition
  • blue is power antena
  • black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
hope this helps
Dec 12, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
What wiring harness and deck install kit?
you should be able to look it up at the place of purchase, stores like wal-mart have books with info for the specific vehicle, online like crutchfield will probably tell you everything you need.
May 26, 2008 | Car Audio & Video
Car Audio & Video Logo
91 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
