My Mitsubishi TV Model # WD 52725,problem is the Power TIMER LED always blinking, I can't turn on the power by push botton and to remote control.Give me some idea where can get this problem from the circuit board.
  • gndamo Sep 09, 2009
    Taran 2005, please tell me what's DM PCB and FMT PCB means. DM and FMT before I'll remove Printed Circuit Board.
  • gndamo Sep 14, 2009
    Taran_2005 you said. If any are bad,replace all of them with part #181P734030. This part number is the one of the circuit board and where is this 680uFD, 16V, 105C, on a circuit board too and what board?. All capacitors that you told me to check, It's already change to DM,FMT board, but still blinking the power led.
  • 10,515 Answers
I am sorry to hear regarding your problem. I can say one more customer affected by what's known as " GREEN BLINKING LIGHT OF DEATH ". This is a common error on your model. Mitsubishi is aware and already offered a Reason for the same .
COPYRIGHT © 2008 MITSUBISHI DIGITAL ELECTRONICS AMERICA, INC.
MDEA Proprietary Information for Use by Authorized Service Centers Only. Not for distribution. All rights reserved.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
The only option would be to check all the above and repair it. If you have knowledge, you can open and check all the above components.
Note - Do not open and try to repair, if do not have knowledge of electrical circuits.
Unless give a call to a local tech or Mitsubishi.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 09, 2009
  • taran_2005
    taran_2005 Sep 09, 2009
    Thanks for your response!!
    I know this would be the next question :), so i have already find a manual for you :-
    http://www.mediafire.com/file/tnnmzg4lez...
    It would explain you all the details you need.
    Download and let me know,if you require more details.
    Thanks.
  • taran_2005
    taran_2005 Sep 15, 2009
    That's why i have sent you a manual as well. Let me again post it.
    It would be able to help find all circuits.
    Hope i helped you.
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
We replaced the V26 dm repair kit and the problem still exists-tv won't turn on . What do you recommend?
Did you also replace the power capacitors on the power board. Usually the DM board and Power board caps together will cause the steady blinking led the DM caps alone only rarely cause the steady blinking led usually its a combination of both boards capoacitors failing.
Feb 17, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 and the timer light continues to blink and I cannot reset it. What can i do to fix this.
1. Timer LED does not stop blinking; suspect the DM PCB part # 934C152001-V28++ 2. Timer LED blinks 70 seconds, pauses then starts blinking again, suspect the E2P PCB part # 935D820001-V28+ 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition.
Feb 17, 2011 | Mitsubishi Televison & Video
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Had a power surge and now the lamp notification is on steadily
This is a common problem and usually shows up when power is interrupted. The capacitors in the micro, digital, and power supply have to be replaced. In my shop, we prefer to send the chassis to Mitsubishi and they repair it. Do you have a local authorized Mitsubishi service center near you?
May 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at www.tvrepairworld.com
Aug 03, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
k24674
