Question about Samsung SCX 4200 All-In-One Laser Printer
SCX-4200 "No Cartridge" error
A paper jam ocurredand I opened the front hatch and took out the cartridge to take out the jammed paper and when I replaced the cartridge. The no cartridge error is displayed even with a replacement cartridge.
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Any tips on how to remove paper from printer,paper jammed underneath draw
pull out cassette and lift up the printer, look carefully for paper stuck, if not paper there pull out cartridge and inspect to samo piece of paper, just look carefully; in final open rear cover and look for a paper, good luck
Jan 31, 2011 | Samsung SCX 4200 All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung scx-5315f printer giving error paper jam 2 inside .
If you have taken apart the printer and checked where all the paper could have jammed up, use compressed air first on the printer. Then, check your toner cartridge. I know on my HP I had a sample toner cartridge and I put another one into the printer. It either was damaged or scratched, etc. and it caused the printer to not respond.
Sep 01, 2009 | Samsung SCX-5315F All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Scx-4200
remove toner cartriage, then u will see the rubber roller under the cartriage, clean it
Aug 04, 2008 | Samsung SCX 4200 All-In-One Laser Printer
SCX-4200 jam
remove the toner box then clean the black colour roller with a wet smooth cloth.
May 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
754 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
