Question about Pacific Digital Computers & Internet
Does the model CW088D get its power from a computer? If so where can I get the cord to connect them together?
  • 3,153 Answers
Yes it does this is an INTERNAL model and you should be looking fo a connector about 1" wide and 1/4 thick
These pics show you what to look for
Note the shape it should only go in one way.
If you dont have any spare connections most computer shops sell a
1 into 2 adaptor that will get you going see the pics again for more idea.
Posted on Sep 09, 2009
Can av plugs get fixed
You can purchase another power cord on eBay. Just put in your computer's model such as Compaq F500. The computer's model, not the power cord model.
If the port (DC Power Jack) where the power cord is broken or loose, then you will have to wiggle it to get it to connect and boot. If it's too far gone it will not boot and the DC Power Jack will have to be replaced.
May 05, 2012 | Compaq Computers & Internet
All the lights on the buttons flashing with error message
Please perform the following steps:
* Take the cartridges out of the unit. Dis connect the unit from the computer.
* Unplug the power cord from the back of the unit.
* Press OK and Cancel buttons together while connecting the power cord back to the unit.
* Now turn on the unit and verify the result.
:) Dr Tony
May 12, 2010 | HP Officejet 5610 All-In-One InkJet...
What do i hook the speakers up with they only came with one cord what else do i use
The one cord will be connected to the computer or any audio output device. The speakers will be connected together through a cord.
Apr 29, 2010 | M-Audio StudioPro 3 Computer Speakers
My printer is showing error oxdo5do1od recycle power how can i over come that
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
CW088D CD-RW Tray ejects with CD in it but not empty
If the tray retracts but doesn't close 100% then it will open back-up. If it is closing fully then returning open then it is a bad drawer switch. It's hard to get to but if you do get in there, a little WD40 lube might help it actuate. Good luck!
Mar 15, 2010 | CyberDrive CW088D CD-RW Burner
Fix a cut power cord
get a electric tape then roll it to the cut cord and then it will fixed for several days
Jan 17, 2010 | Aspen Refrigerators
HP a820n No Power-up after City Power Failure
You have a bad power supply. It is not an expensive fix. Remember HP's take HP power supplies. When ordering either look on ebay for your model or order from part supplier.
Aug 22, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
Power cord has been cut
Yes you can replace the entire cord, or you can splice the cord back together. Get some crimp on wire connectors get a tube of heat shrink that will fit over the cord, cut back the insulation crimp, the wires back together (match color to color). heat the shrink or tape it up. Back in business.
Jul 04, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
Power cord
You may have a broken solder connection - some sort of broken or intermittent connection. Common problems are broken solder connections at the power jack (inside the laptop). If this is the case, the laptop will need to be disassembled for repairs to be made. Note: There are online sites with DC power jacks available, crossed by Model number.
Wiring can also break (external to the laptop) especially if the wire/cord is flexed frequently (like when wrapped up to put into the laptop bag). Sometimes there is no external evidence of a break.
Also, if indeed your laptop has a pig-tale as you describe, the jack where you connect might be worn out- just not making contact with the plug.
Find someone with a little tech savvy, if necessary, and locate the exact nature of the bad connection, and make repairs from there.
Jul 03, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top Pacific Digital Computers & Internet Experts
John Ware
John Ware
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Pacific Digital Computer and Internet Expert? Answer questions, earn points and help others
