Question about Frigidaire FSC23F7D Side by Side Refrigerator
I have a side by side frigidaire with water and ice maker.
After changing my water filter my wife and i realized the refrigerator wasn't wworking. it is only four years old. a friend of mine said to unplug it for about five minutes and maybe it would reset itself, but it didn't. i can tell it's working because there's some cold air coming from the bottom portion of the unit when the door is open, but it's not worki ng right. please help.
oscar
  • 44 Answers
Oscar, can you please describe what specifically is not working right? I can't tell from your description what it is specifically that is not working. Thanks - Dr. Know
Posted on Dec 23, 2007
I have a Frigidaire refrigerator and the ice maker does not make ice, water works but no ice?
is the tray for cubes filling with water .if not check for blockage of tube
Jul 23, 2015 | Frigidaire Refrigerators
Frigidaire KSRA22 CNWHOO Side-by-Side refrigerator, Serial # SS1241434 I just changed the filter in my Frigidaire refrigerator. It had stopped making ice when the filter light came on. However, now...
Are you getting any water.
If you push the tab for water any you hear a buzzing or humming sound with no water then it could be you water pump which is located at the back of the fridge.
Just follow the water line and you will find it .
It's a small pump
May 26, 2017 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Jul 24, 2009 | Frigidaire FRS23KF7AB Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
ICE MAKER
remove the water filter and check the water filter inlet tube
do you have water in the door?
hope it helps
Jul 03, 2008 | Frigidaire FRS26R4A Side by Side...
ICE MAKER...NO WATER IN ICE PAN
do you have water thru the door? you may have air in the line. filter incorrectly installed / or a bad water valve
let me know
Apr 04, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Frigidaire FSC23F7D Side by Side Refrigerator Logo
102 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
