Question about Briggs & Stratton Garden
Gas is pouring out my exhaust i checked the float and it seems ok needle is moving ok this is on a 19 hp briggs 2000 model any ideas
  • 69 Answers
Your float may need to be adjusted to the correct measurements. The Briggs website probably has the details.
Posted on Sep 09, 2009
Gas pours out of carb and muffler
float could be ok but the needle and seat or bad replace them
Aug 16, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Briggs engine is pouring gas out the carb
Take the float bowl off and replace the float needle and seat after you make sure every thing is clean. Make sure the float pin is smooth and not rusted and shake the float to make sure and listen to see if there is a hole in it and fuel got in the float. When you put the carb back together with the float side facing you adjust it so it is level when gravity is holding it closed position.
May 24, 2014 | Briggs and Stratton 073001 2" Portable Gas...
I have an excell pressure washer vr2500 with a 6.5 hp Briggs and Stratton motor after pouring gas into empty gas tank see gas leaking from carburetor
YOU HAVE A FLOAT IN THE CARBURETOR THAT MAY BE STUCK THERE IS A SMALL NEEDLE VAULE THAT ALSO MAY BE STICKING YOU CAN GET A REBUILT KIT FOR THE CARBURETOR
Feb 23, 2014 | Cam Spray 25006BX 2500 PSI Cold Water Gas...
Gas ran out of sparkplug hole
If you had raw gas in the cylinder to where it poured out of the plug hole you most likely have a carburator problem. Inside the carburator is a float and needle, the float pushes the needle into a seat when the bowl is full of gas so no more gas will flow into the bowl or the engine. If the float won't float or the needle is damaged or has dirt between it and the seat the gas will continue to flow into the carburator and on into the engine. If enough gas gets into the cylinder the starter won't be able to turn the motor over. You should also check your oil, usually when gas gets into the cylinder it runs into the crankcase and thins the oil to where it will damage the motor if run for any length of time.
May 09, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Model 42a707 engine spitting gas out of carberator
Fuel needle leaking in the carb, remove the float bowl, check the float is moving freely, clean away any dirt, if no better replace the inlet needle.
May 06, 2012 | Yard Machines Garden
While trying to start gas pourred out of the exhaust
The needle valve in the carb evidently is not seating and allowing way too much fuel to continually enter into the fuel system. Remove the carbs float bowl to check for this. Float pushed up...should be no gas flow...float hanging down..gas should flow. The needle valve is probably either sticking open or debris in the seating area is not allowing it to seat (which shuts off the gas flow).
Sep 13, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Gas pouring into carberator
The float has the needle wide open letting fuel just flow. The float keeps the needle seated into a hole by "floating". try taking off the bowl and see if the needle is out or it may be a good idea to put in a new one. $5 for a kit.
Apr 26, 2010 | Briggs & Stratton Power Products 5,550...
Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Sep 06, 2009 | Garden
Gas coming out of exhaust is it the carburetor and why
carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
May 23, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Yamaha Grizzly 600 leaking gas
if the carb was really cleaned out, then i would suspect the float is not set properly (where #14 in the pic meets #19, assuming it is adjustable), the float (#14) has a hole in it and is no longer "floating" which turns off fuel to the bowl when it raises #19 (needle valve) or the needle valve is not connected properly to the float (common problem when reassembling a carb.
http://partsfinder.onlinemicrofiche.com/atlanticcycleandpower/Yamaha_OEM/YamahaATV.asp?Type=18&A=268&B=11&Action=O
one way to check is to remove the float bowl and with your finger, push the float up (it pivots) and turn on the petcock. if fuel still pours out the needle valve, then the needle valve may not be connected properly to the float or the needle valve is worn. if it doesn't pour out, then i would replace the float as it is no longer floating (one way to also tell is if you see fuel inside the float if its plastic) to turn off fuel or adjust the float tang (assuming the float is brass. if its plastic, then there is no adjustment). good luck.
Jan 26, 2009 | 2000 Yamaha TT 600 R
Garden Logo
143 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
