Question about HP LaserJet 4600dn Color Printer
Need to have 4600 laser printer in just black ,because of broken
Have hp 4600 dn laserjet ,the yellow laser/scanner assembly is broken...i need to if there is a way to make this printer just print in black and white while i get the money to have it fixed.it always defualts to the 51.2y error and wont print any documents.thanks
  • 65 Answers
Sorry, my friend, there is no way to force it go B/W and override the error message.
Posted on Sep 09, 2009
Testimonial: "thanks for ur help tidyboy0558 "
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Why do I get 3 groans during calibration accompanied by a 51.2m error ?
51.2 is a laser error.
there should be another number after the 2,
0 = black laser
1 = cyan laser
2 = magenta laser
3 = yellow laser.
The groan is most likely the polygon motor has lost its lubrication and may just need to be cleaned and re-lubricated.
You can also try reseating the connectors from the lasers to the DC controller PCB...
Jul 19, 2014 | HP LaserJet 4600 Printer
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
51.XY
X Description:
1=beam detect error
2=laser error ***
Y Description:
0=black ***
1=cyan
2=magenta
3=yellow
Replace the black laser assembly !
Mar 13, 2014 | HP LaserJet 4600 Printer
My laserjet 4600 is showing 51.2k error can someone help to fix it
This error due to black scanner scanner no 1,take the help of expert or open with common sence first remove all the covers remove the formatter from back side then you will find the laser scanner ,you will find the two lever locks(arms)left & right.
pull out the no 1 scaner open the cover & clean the scanner internally with soft cotton & also clean the spendel motor phase. I think your problem will be resolved.Dont forget to calibrate the printer at least three times. thanks reply if resolved
Sep 29, 2010 | HP LaserJet 4600 Printer
Hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Mar 30, 2010 | HP LaserJet 1012 Printer
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
Aug 12, 2009 | HP LaserJet 4600 Printer
HP 4600 printer with error message 51.2M and loud noise when calibrating. Any solution?
Replace your magenta cartridge first. If the problem persist I strongly recommend a service tech. Error 51.2M is an magenta scanner(laser) error or DC controller.
May 08, 2009 | HP LaserJet 4600 Printer
How to install an Hplj 4600 laserunit
NO . just make sure you replace the black laser.
Apr 06, 2009 | HP LaserJet 4600 Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 4600dn Color Printer Logo
272 people viewed this question
Seeker5211
Seeker5211
