Question about Olympus Stylus 820 Digital Camera
Grainy pictures...iso problem for olympus stylus 820
On auto iso setting (olympus stylus 820), pictures are grainy with what looks almost like a finger print on the picture/screen.  The higher the iso, the worse it is.  Even on iso 50, the pictures are not clear.  Digital zoom is turned off, flash settings make no difference.  Is there a way to turn iso off?  Any other ideas????
Thanks.
  • 1 more comment
  • mattvedder Sep 10, 2009
    As I mentioned in my first post, I've tried all the iso settings, no real change. The lower the iso, the less grainy the photo is but regardless, there are still grainy white lines running through the photo.
    Brigadier General:
  • 4,090 Answers
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Posted on Sep 10, 2009
SOURCE:
Underwater photography problems with MJU 740
hmmm..well...let's see...poor resolution comes from one of two sources.
focal lengthe issues..
ocular clarity.
guess we'll try focal length...did you check to see that the housing and the lens are compatible, and perhaps you are experiencing refraction 101?
Apr 02, 2008 | Olympus Stylus 740 Digital Camera
Is there a way to find out the iso setting used on a specific picture
In most photo-editing programs, if you click on details or info or metadata, etc. you will get complete details.
Nov 22, 2009 | Olympus Stylus 820 Digital Camera
Not good photos indoors very grainy and bad light looking photos
Auto mode in poor lighting (generally always indoors without flash) sets high ISO, which produces ugly amount of noise (graininess). What you need is to keep the ISO under 200 by either:
Shooting well lit scenes, using flash etc.
or
Uusing one of the manual programs (M, S, A, P) and setting the sensitivity via the F-menu.
Dec 27, 2008 | Fuji FinePix S8000fd Digital Camera
Pictures come out very grainy
Most likely, you've set the ISO value higher than necessary for most circumstances. You may have done this deliberately to catch some fast action, or you accidentally hit the ISO button without realizing it. If you reset to lower ISO settings, your graininess problem will probably disappear.
The faster the "film speed", whether you're using real film or a digital camera, the more grainy the pictures will be. ISO is the film speed. The ISO speed is set by pressing the ISO button (just above the "FUNC SET" button); it cycles thru AUTO, HI, 80,100, 200, 400, 800, 1600, then back to AUTO. If you've set the camera to AUTO on the control wheel opn the top of the camera, then you can only select ISO of AUTO or HI (which is slightly faster than AUTO).
The higher ISO settings are useful in low light conditions or to catch fast action, but those higher settings should not be used otherwise because of the increased graininess.
I hope this helps you.
Oct 19, 2008 | Canon PowerShot A540 Digital Camera
Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
Grainy Pictures
This camera with the ISO set to 100 ASA, the electronic zoom turned off, and with the mode on Automatic "A", should take very good pictures.
I would give the camera to the manufacture for service, and include some samples of what the results are. It would be recomended to do this while the camera is under warranty.
Jerry G.
Apr 27, 2008 | Olympus Stylus 820 Digital Camera
Grainy Pictures
it could be a problem with CCD, and that can just be replaced in a service centre.
Jan 15, 2007 | Olympus Stylus 710 Digital Camera
Grainy Pictures
With the iso set on auto mode it will change depending on the light and anything above iso 200 is very bad on this camera i know have the 717 and it does a lot better but if you can set the iso yourself and take it off auto allways use 100 or 200 for low grain.
Sep 13, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Olympus Stylus 820 Digital Camera Logo
357 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
