Question about Nintendo Wrecking Crew: Entertaiment System for Nintendo
I have a classic NES system with a power cord and a cord for "TV In". None of my televisions have a female TV In. I am sure it is simple but what is the proper port for this single connector?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 111 Answers
I'm pretty sure NES connects with a coax. Plug it to your cable tv inlet on your tv. Plug your cable tv cord to the back of the nes adapter.
Posted on Nov 27, 2009
Can you use a power cord from a Samsung 39 inch flat screen on a Samsung 65 inch flatscreen
yes, most tv's that i know of take two types of power cords, both of which are ok to mixmatch. As long as the new tv uses a molded u ground cable (3 holes on female end) or the smaller ones (2 round holes on female end) which most do it is perfectly safe to do so. As long as the tv did not have the box attached to cord ( regulates wattage) if that is the case you need one that supplies the EXACT wattage to the tv but i have yet to run into a tv that uses a power cord like that.
Feb 21, 2015 | Samsung Televison & Video
Nothing happening when hit power button....
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
Sep 17, 2007 | Nintendo NES Console
Cut power cord for Sony Bravia kdf-50e3000
I am not sure what you are asking. If the cord is to be replaced, in some cases a computer cord is compatible. You may remove the female end and insert a computer power cord. Many of these flat screen TVs do have a removable power cord. In the case this cord is attached internally, you will need to find a TV shop to replace it. If this is the case, they will be sure to install with correct polarity. Thanks for asking and show all hands of support!
Aug 15, 2011 | Sony Televison & Video
Need a replacement power cord for dp26649. the tv had a different power cord then is normally seen. it was made in mexico. it has a round connection on the back with four little holes in it and we cant...
Tries websites like Partstore.com,Amazon.com,Ebay.com to find and buy that a/c power cord.These three websites have the most acessaries for tvs components around.
Jul 08, 2011 | Sanyo DP26649 26 in. TV
My tv no power
Please check carefully your :
1. Power cord ( check the present of power at end of the cord)
2. Fuse ( Your Tv should has a safety fuse, It may blown)
3. Power supply circuit ( if none of above problem)
Note that a totally dead TV usually cause by simple thing.
Nov 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Fuzzy picture on TV and NES when new RF adapter is cconnected
i had the same problem, and it was the rf unit itself. to resolve this problem i went to radio shack and purchased a special connecter. one side is an rca (male) to rf (female). when attached to a standard peice of cable wire, it acts as an rf unit. Also works with the sega genesis. hope that helped
Mar 30, 2009 | Nintendo NES Console
Hooking it up?!
ummm the cable is outdated on most televisions try  using the av jacks on the side of the system those worked well for me.
May 04, 2008 | Nintendo NES Console
NES in Black and white only...?!
Thats quite a odd issue, and I have never heard or seen a case such as this. Maybe your color balance chip is fried? NES is a 20+ year old system, so I wouldn't doubt the NES may have more issues then just a lockout chip error or a new pin connector.
Dec 25, 2007 | Nintendo NES Console
Problem with NES
Check on the back of the nintendo system if it is on same channel as tv, little switch is on the back next to the power cord.
example..tv channel 3 and nintendo system channel 3
If that doesn't work your cable is not properly connected, You can't use both rf switch and av cable. It one or the other. rf connect in the back and to coax cable. Av cable connect on the right side of the system and front input on tv..
Make sure your games are clean also. Good Luck.
Nintendo Wrecking Crew: Entertaiment System for   Nintendo Logo
164 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
