Hi there i bourght an amcap camera i installed it and it says on the screen cannot run preview grapH:P what do i do plz help
  • 555 Answers
This issue is usually caused by the graphic interface is not supported. You need to verify that you have the newer version of DirectX. To check the version number click START, select RUN and type DXDIAG to bring up the DirectX Diagnostic.
If everything appears to be ok, make sure the web cam driver is properly installed along with the video driver (video card). Please update the DirectX version of Windows if you got an older version.
If it doesn't work. try:
Check Properties of "My Computer> Hardware> Device Manager" you have any device with an exclamation mark or cross in yellow or red, respectively.
If you do not have anything like that, check if your webcam device appears in the listing.
If that doesn't work or there is no error on properties, another driver may be causing problems. you may need to go a little technical about this issue following the steps below:
1) install the drivers by disabling all the non Microsoft services on your system.
2) uninstall the web cam drivers.
3) unplug the web cam and need to reboot your system.
4) Then you need to go on your Start menu, then select Run and then type: msconfig and press the enter key.
5) on the General tab,you need to click on Selective Startup.
6) Under Selective Startup, you need to click on clear the Load Startup Items check box.
7) Then again click on the Services tab, then you need to select the Hide All Microsoft Services check box, and then you need to click on Disable All.
8) Then click on OK. Then it ask you whether you would like to reboot your system,just click on Restart.
9) Install the driver.
10) Plugin the webcam.
11) Restart the computer.
After doing all this still doesn't work, the issue may be caused by some kind of incompatible hardware.
Posted on Sep 09, 2009
I have a Nikon D80 camera. I somehow, unintentionally turned on the preview screen that shows all of the info. I don't want any print on my screen, no highlight, no RGB, nothing but picture.
If you were seeing a preview on the LCD monitor on the back of the camera, then there was something seriously wrong with the camera. Nikon did not introduce the LiveView feature until later models.
If you're asking about review instead of preview and seeing graphs or lots of data, press up/down on the multiselector to cycle through different views of your pictures until you get to one you like.
Nov 19, 2011 | Nikon D80 Digital Camera
Hi ,I was installing my TEAC webcam and after the installation was finished and I rebooted the computer, I got Blank white screen on the amcap preview... Any ideas? (Windows 7)
You need to configure the image settings - start with the focus lens, then the brightness and contrast settings that you can find in Options - Video capture.
Sep 26, 2010 | Computers & Internet
I'm struggling using the webcam on the laptop- can't seem to find any options on it to get it going! Can you advise?
Download  AMCAP2, from here,
http://en.softonic.com/s/amcap-2.0-webcam
OK, install the "Driver" then plug in camera. Then run Amcap select your webcam from  the "Devices" tab, also check the Preview under the "Options" tab. You should be able to see an image.
If it is all OK, get yourself a good WebCam software and use that if you wish.
Feb 01, 2010 | Computers & Internet
AMcap white screen DC - 7120
yep you click on options in the amcap screen then click preview then the picture should come up
Aug 29, 2009 | Computers & Internet
Trust WB-3420N webcam live doesn't work on my laptop
As I had a similar problemn, I just tried to install the driver from the CD that came with the webcam. Worked like sunshine!!!
Jun 16, 2009 | Video Cameras
Mikomi M6607M - wont show the image/video on screen
Normal 0 Double Click on this site
http://www.free-codecs.com/download/AMCap.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multimonitoring support, zooming, aspect ratio and deinterlacing features.
AMCap is a small and effictive piece of software and definitely worth trying. Hope this will help. Bud
Jan 08, 2009 | Computers & Internet
My amcap webcam has a black screen but was working before how can i repair this
Normal 0 Preview capture may appear black
In some cases, the preview capture may not appear.
To fix this:
- Unplug the webcam while itss showing the black screen, wait a couple seconds and plug it back in.
- Or -
Lower the video resolution.
Hope this helps. Bud
Dec 01, 2008 | Trust SpaceCam 100 Webcam
Amcap its saying error 80070450:cannot run preview graph
No solution yet, I restarted my computer but, the same problem/error appeared. I will be greatful for your help.
Nov 22, 2008 | MSI Starcam 370i Webcam
Webcam not working
Hi speed USB Device attached to non Hi Speed Hub.... this message appears because the USB hub controller is not updated. Try to download USB 2 driver from the following. http://www.softwarepatch.com/tips/usb2-driver.html
Another application already using webcam--- for this error message... try this.. right click my computer. Properties-> hardware tab. -> device manager. check any abnormal marks like a yellow circle or yellow question marks in the cam . also check the COM ports.
Dec 29, 2007 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
465 people viewed this question
David Payne
David Payne
