Question about Dell InspironTM 1501 Notebook
Inspiron 1501 screen went black and will come on intermitently for a fiew min here and their. When it comes on or off i here a buzz. If i dim the screen all the way with the brightness cntrl the screen will stay on longer. But if i try to go up from the lowest setting it will buzz out again. From the reading ive done it sounds like a possibal inverter? I have found one on ebay but want to confirm if this will fix the problem. And 2 i need directions on how to replace it if i do buy it. Is their a link on dells site with directions? i could not find one.
  • 70 Answers
You may need a new lcd screen i had the same problem with my advent laptop.
Posted on Sep 09, 2009
Dell Inspiron 2200 boots up but 1-2 min in the screen goes to a faint black. You can still see the desktop and everything just very faintly. Like a fain transparent black.
Check with your Power Plan or screen saver option, you might have it adjusted to super energy saving to make your battery last longer and have the screen dim, or backlight shut off since you mention it take 1-2 min to boot up ...see if that might help.... If that didn't do the job, I suspect your backlit lighting might be going bad. Let me know what Operating system you are using too. So like I said, check your screen save and if it is set to dim, or shurt off withing a minute or two... set it to something longer to see if that works.
Jan 15, 2011 | Dell Inspiron 2200 Notebook
The light in the screen went dim and hitting the fn key and up arrow doesn't help. how do i fix it.
first of all check your key board fn keys weither its works or not,if its work it is mean your lcd light went down and you have to change you laptop screen or contact expert for fixing it with new light rod.
Jun 27, 2010 | Dell Inspiron 1501 Notebook
My dell inspiron 1100 screen goes black
Fist ot alla, try to connect the notebook to an external monitor and check if you can show image when the issue appare.
Oct 19, 2009 | Dell Inspiron 1100 Notebook
Inspiron 1501 startup problem
hi,
-this is a possible problem in the memory of the computer
-if you are familiar in opening the computer and removing and returning back the memory please reseat the memory; if not contact your manufacturer for possible memory replacement
cheers!
Oct 18, 2009 | Dell Inspiron 1501 Notebook
My dell inspiron 1501 laptop has been flickeri ng colors or a lrge strip down middle , now half the screen is black with little color line
hello
This could be anything from the screen is dying or the inverter (electronic board that powers the screen' back light).
If you press slightly at the top of the screen, see if the lines will disappear or not, if it does then come back again; you might need to change your lcd.
hope it helped
TekSpotDotCoDotUK
Aug 26, 2009 | Dell Inspiron 1501 Notebook
MY DELL INSPIRON 1501 IS NOT WORKING, THE BLACK
  1. Chck the ram i thinkg ram is not working
  2. insttal the oprating system in your system and remove the old after working fine
Jul 14, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Dell InspironTM 1501 Notebook
Dell Inspiron 1501, died and will not restart
Try to remove the battery and unplug the power supply, then hold down the power button for about 10 seconds. If this doesn't work, it could be that the laptop overheated while watching the DVD.
Mar 25, 2009 | Dell Inspiron 1501 Notebook
Dell InspironTM 1501 Notebook Logo
100 people viewed this question
Alun Cox
