I have taken a Seagate 5400.2 60GB hard disk out of a broken Sony PS3 and put it into a case to use as an external drive for my Dell laptop running Vista. The computer recognises thst the device is presnt but I cannot get the machine to address it. Help please.
    President:
  • 1,187 Answers
You will have to "destroy" the data that is on the disk... If that is ok then:
1. Right-click "My Computer" and select "Manage" from the drop-down menu.
2. Select "Disk Management"
3. A graph of the disks in the computer will appear.
4. Go to "Full Screen" (maximize your window).
5. Find the Seagate disk (may be marked "Unknown").
6. If you are absolutely sure that this is the Seagate out of the Sony PS3 .. .then right-click on the graph that represents the Seagate and "Delete Partition" (The system will not allow you to delete your boot drive partition.
7. Once it has been deleted, you can "Create Partition" (choose "Primary" partition) and do not use a fast (quick) format.
8. You probably know the rest.... (Create drive, FAT32, etc.)
Hope this is what you want...
Posted on Sep 09, 2009
I'm having the same problem but mine isn't evn showing up in disk management yet was working in a ps3 less then 15 mins ago?
Posted on Mar 02, 2013
How can I find the files on my 1tb, seagate external drive?
You maybe removed the driver for the hard drive when you ran the anti virus. Those programs can do some strange things. If you click on the start, then computer. It will show all hard drives on your system. If you cannot find your files. I would think your computer does not see the external hard drive. To reinstall the driver, you would need to go to the driver's manufactures web site to down load or yours may have came with a disk. If so just run the disk. Could do a system restore , but that would be last option .
Aug 02, 2014 | Seagate FreeAgent Pro 1TB External USB...
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate external hard drive
In this case the MOST effective way is to try some data recovery program to see if it can help rescue your data on your Seagate external.
Oct 24, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Seagate 500 external hardrive
It could be that the PCB or the connection within the external casing has a problem.
Try disassembling it and putting the Hard Disk into another external case to see if the disk is okay, if it is then viola! you have your data back.
Jan 14, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Using hard drive on a Mac
If the drive is empty, use disk utility to reformat the drive as HFS+. DO NOT DO THIS IF YOU HAVE DATA ON THE DRIVE!!! :-)
Dec 03, 2007 | Seagate 160GB 3.5" External USB Drive 160...
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
