Question about GE WDSR2080D Top Load Washer
GE washer overfills - GE WDSR2080D Top Load Washer
  • 1 more comment
  • jbohler32 Feb 29, 2008
    I have a GE wdsr2080d waher that doesnt know when to stop filling with water, the technicians came out and said I need a new motor without even testing my machine and ideas on what I should and can look for to test it?
    Please and Thank You,
    Jenn
  • storywell Dec 23, 2008
    When mine fills during rinse cycle, it keeps filling after it is supposed to stop. When I turn the level selector switch I can get it to stop. Is it the switch or the valve?
  • seabresmom Jan 21, 2009
    I have had a GE repair man to my home multiple times, and they will not consider it a lemon because it isnt the same problem going out all the time. The knobs strip, it will not go into the spin mode now, and it sticks between heavy and medium load, if you dont help it advance. It also over flows on the super load, and as of today the large load as well. VERY DISAPPOINTED in this product that isnt even 2 yrs old. I am still paying this washer off, and had to go buy a new one today!
    Problem Solver:
  • 12 Answers
Water Level Pressure Switch may be fault.
Check www.repairclinic.com for parts.
Posted on Dec 23, 2008
    Problem Solver:
  • 7 Answers
Water level switch or obstruction.
Posted on Dec 24, 2007
Jimster
  • 240 Answers
SOURCE: GE Washer overfilled, now won't spin
Could possibly be that the water level switch in the console has gone bad.  Sometimes the small hose that connects the basket and the switch can come off, causing the overfill.  Sounds like maybe the water switch has gone bad though if I were to guess at it.  If it goes bad, it will send the timer a signal that its full, when its not.  Could also be a bad timer, but that only happens on rare occasions, but it does happen.  Let me know how it goes or if you need break down instructions, etc.  Jim
Posted on Oct 17, 2007
  • 41 Answers
SOURCE: GE washer
mostly likely your pressure switch has gone bad or the hose has come loose from the pressure switch. open access to the console. your pressure switch is the water level. if the hose is attached, then the switch itself is bad. Joe
Posted on Nov 18, 2008
MNTECH
  • 1543 Answers
SOURCE: My GE washer (modelWBB4500E1WW) overflows about
Remove the front panel by using a putty knife to depress the retaining clips at the seam where it meets the washer top. (one on each side) Take the thin hose off the lower left side of the outer tub and clean it out. A short cut would be to cut off an inch and a half of it, but that's a one time fix, then the hose starts getting too short. To help prevent re-occourance, run a small hot load with a couple cups of bleach (no clothes) every few months. Make sure to rinse the tub on the largest level to prevent bleach damage to your next wash load.
Posted on Oct 18, 2009
Testimonial: "Thanks!"
woodchuck789
  • 4070 Answers
SOURCE: my ge washer overfills from time to time...model
I think that from time to time your water inlet valve is sticking and not cutting off. This can be caused by sediment in the water or wear on the valve. The cold water valve is the one which usually sticks. The valve is on the back where the water hose connects to the washer. Replace it or flush and blow it out and make sure the wire strainer is in the other end of hose.
Posted on Jan 26, 2010
  • 44 Answers
SOURCE: Our GE washer model #: WCVH6800J1WW is overfilling
When you replaced the pressure switch, did you fully test the pressure switch hose?
Here's a similar posting that explains a potential issue and how to troubleshoot:
http://www.fixya.com/support/t8933273-general_electirc_washer_model
I highly recommend doing a diagnostic test because it's free and easy. Most of the time, the washer will self-diagnose. Check out that posting for instructions on how to do the tests.
Posted on Jul 28, 2011
Not geting the cold water. Only once and a while even though set on Bright colors
Fixing a Washing Machine with Slow or No Cold Water Fill ...
? 7:40
www.youtube.com/watch?v=c5r49nuMjao
Feb 10, 2014 - Uploaded by SamuraiRepairman On washers with this problem that do the rinse cycle with coldwater only, the ... Top comments .... It's a front loading machine so I can't open it when it's on. .... GE Washing Machine Repair - Water Overfills, Overflows Washer ...
Aug 09, 2015 | GE WHSE5240D Top Load Washer
Washer overfills & excess comes out from underneath
what is your model number then we can get started then okay
Feb 11, 2013 | GE WBSR3140DW Top Load Washer
GE frontload washer shaking during wash
belt may be loose unless its too overfilled or it may be unlevel on ground
Dec 01, 2010 | GE WSXH208A Front Load Washer
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 14, 2009 | GE WVSR1060A Top Load Washer
My GE Washer model # WDSR2080DAWW is overfilling unless I take the hose off the side that controls the load indicator switch and blow air into, once I do that, it will stop filling and work perfectly, how...
I fixed my washer by taking off the hose that controls the load indicator switch and blew air into it and it works like a charm, so please don't charge me 20 dollars cause i fixed it myself, thanks
May 13, 2009 | GE WBSE2090A Top Load Washer
Occasionally it will overfill
The water level switch is your problem.
Open the control panel and remove the plastic hose from the level switch and blow through it.
Soap and dirt clog the bottom end and prevents the switch from stopping. The water continues to flow because of this blockage.
After you reattach the plastic hose , set the washer to spin and turn it on to reset the switch.
Mar 15, 2009 | GE WBSR3140DW Top Load Washer
GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
Feb 19, 2009 | GE WBSR3140DW Top Load Washer
GE washer
Nov 18, 2008 | GE Washing Machines
Oct 16, 2007 | GE WJSR4160D Top Load Washer
GE WDSR2080D Top Load Washer Logo
282 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
