Question about RIM BlackBerry? Curve 8330 Cellular Phone
My BB 8330 would not accept my PW to unlock and wiped my BB!Help!
Upon entering the screensaver, my BB locked and asked me for my password. I always enter the same number sequence, and my device is always then unlocked. This time, it would not accept my password, and said that it was going to wipe upon one more failed attempt. I entered carefully and correctly the number sequence, and a wipe screen was initiated. I don't understand what happened! Now the screen says 'JVM Error 513' and gives me the option of resetting. Except, when I click on 'reset' nothing happens. What do I do?! I don't have the Device Desktop manager installed on my computer yet, can this be fixed!??!?! I don't have the money for a new phone!
I have a blackberry curve 8330. I put it in my pocket and it locked but I do not have a password. What do I do to unlock the phone? I am on the lst attempt to unlock it.
You can try this solution to unlock blackberry curve 8330 password but you can't save your data. Type any password 10 times and it will erase all your previous data, after your blackberry unlocked you can create your own password.
Jun 21, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
I forgot the password for my sprint blackberry curve 8330
only solution is to enter password wrong 10 times, beware by doing this you will loose all your phone contacts messages etc. then it will wipe the handset and ask for new password.
regards
Jan 05, 2011 | Cell Phones
Blackberry 8330, when I try to enter my password to access my phone, it does not show the usual "****" and it won't accept my password. I have only 1 attemp left before it locks my phone.
are u sure you keypad working normally. connect with blackberry desktop manager software in pc, it will ask for password, give password on pc than take backup of your important data first. if you still not able to put code than you can enter any code and it will wipe your handset and you might be able to put a new password again.
Apr 28, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry pearl is locked and will not let me turn it on
If it is a network umlock code you need to contact you're service provider.
if it is a keypad unlock code kindly enter wrong password for 10 time's you're Handheld will get wiped off. Then it will ask for reset password, Enter the new password and remember that.
NOTE:- No data will be available when your Handheld is wiped off.
Ihope I was able to help you.
Thank you for using Fixya.
Oct 20, 2009 | RIM BlackBerry Pearl 8100
I have my bb 8100 imei number but it wont unlock?
With the help of IMEI number you cannot unlock the Handheld,
If it is a network unlock code you need to contact you're service provider.
Oct 16, 2009 | RIM BlackBerry Pearl 8100
Forgot paasword to unlock blackberry curve 8330
unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry curve 8830 Unlock Code. Buy your unlock code from third party. i hope this information is help you :)Good Luck
Sep 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
I use a security code on my BB Curve 8330. I
I had the same problem a while ago you need to set the "key stores" password you do this by going to options select security the select key stores and when your in there hit the blackberry button on your keypad and then select "change password" then enter your password you want then you should be good to go next time you connect your phone to your computer because you just enter that password you did there on the computer and then you're all done!
Kyle
Jul 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Last night I tried to use my BB=8330, but it ask for a password. I had no such PW so I tried several times only to reach a point were I entered a wipe menue and initiated. Now all that is showing is a...
try to reset again.if not full flashing is necessary in order to work it properly.if you are here in the philippines you can contact w/ me thru this address:exel_bernardo@yahoo.com.thanks
Jul 07, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackeberry 8300 hard reset
Well, I am not sure if it was a solution, but you may wish to ask your IT admin, if they sent the new IT policy to your BB without notifying you in advance. It has happenned to me today, our IT department sent out an admin command to all BB used in the company to set the new PW and the users are not allowed to disable this function, only the BB admin can do so.
In other words: it is a feature, not a bug...
Hope it helps.
Outsider
Aug 12, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry? Curve 8330 Cellular Phone Logo
142 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
