Question about Kenmore Elite 45986 Front Load Washer
I am getting the F85 error - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
F85 is not a valid error.
F35 perhaps?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How clear code f85 nissan forkleft
here is a caterpillar site that showed up in the search for the nissan maybe these may help you figure if you can clear this one.
if it is the forward solenoid like it says here you need to fix it before you can reset it. try both these sites and see if you get your answer.
https://www.fixaforklift.com/caterpillar-lp-gas-forklifts-f11/basic-code-charts-t78
FORKLIFT NISSAN REPAIR UNICARRIERS ERROR CODE NISSAN FORKLIFT New Nissan...
Dec 12, 2017 | Miscellaneous
Sole F85 E2 error code. Have adjusted the sensor several times along with running recalibration. All grounds and board connections seem to be secure. What else should I check. Unit worked until we...
If it was moved . Most likely the cable was damaged where the right upright bar slides into the frame. You will need to take the console off and remove the right upright , too access the cable. Unless you live in NC you could call, wilsons triad fitness 336-313-6253
Dec 08, 2017 | Sole Fitness Sole F85 Treadmill
Sole F85 Hand Rail Incline Adjustment Switch is not working
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
Aug 12, 2013 | Sole Fitness Sole F85 Treadmill
Sole F85 treadmill fan and hand controls not working
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
Jan 30, 2013 | Sole Fitness Sole F85 Treadmill
F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
sincerely. God bless you
Apr 13, 2012 | Sole Fitness Sole F85 Treadmill
My dishwasher stops and flashes up F85 can you tell me what this means please?
Fault code F85: Slide shutter signal change fault.
Defective shutter system, inside circulation pump. Circulation pump needs to be replaced.
Oct 05, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele dishwasher had F85 on the screen
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F85 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
Apr 28, 2010 | Miele Premier-Plus Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
102 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
