Question about Toshiba TZ55V61 55" Rear Projection Television
Toshiba 55" rear projection
The colors on my tv split and I can see a red green and blue picture, then the picture starts to scroll and shuts off the screen and the power light blinks and I have to pull the plug to reset it. what do I do?
  • tvsbroke Dec 10, 2007
    can this be done at my house or does it need to go to a shop??
  • 232 Answers
Hi, convergence circuit has failed, the IC`s will have to be changed,possibly a couple of precision support resistors as well and the set will then need to be re-converged, More questions? feel free to ask away, Happy Holidays, BMW Rider
Posted on Dec 10, 2007
  • Larry Eastman
    Larry Eastman Dec 10, 2007
    that depends on the shops in your area, some pull the set to the shop and some will repair it in the home, you`ll have to call around your area to see how they do it, theres only one shop in my county that fixes in the home and that`s me, good luck, BMW Rider
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
It won't turn on. The red light blinks and a click in the rear but the light does not stay on and no picture. If you keep trying the start button often (50) sometimes it will start. Once on, it will shut...
STK392-110 IC's. This problem is mentioned all over the place here.
Quick test: Remove the back cover. At the center of the closest side of the circuit board are 3 identical plugs. The circuit board will be labeled "Red, Green, Blue" and the plugs will have some matching indicator. Mine are colored-marker stripes.
Unplug all three. Turn on the set. If it continues to run but the picture is a mess -- it's the ICs. Use STK392-110T or STK392-118.
Replacing these takes a fair amount of skill with a soldering iron and familiarity with TV service. Or a death wish.
Dec 18, 2009 | Toshiba 55H70 55" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 55H81 Blue and Red Only
so you missing the green is is either a bad connection on the green crt or convergence amp ic bad
do this first
then if that doesnt fix it
Jan 23, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 65NH84
You might have burned out the red color crt. In projection TV's there are 3 CRT's (one for blue one for red, and one for green). If you have the other 2 colors but no red I would assume this is your problem. You should be able to get it fixed for around $150.
Jan 13, 2008 | Toshiba 65HX81 65" Rear Projection...
Bad picture
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Nov 29, 2007 | Toshiba 55H70 55" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Picture has turned green
Possible green CRT bad....remove lower front speaker cover
and access panel.......carefully disconnect green PC board
from green CRT ( center tube )....plug in TV..power set....should have steady red/blue pix (no green) = bad green CRT............T.
Oct 27, 2007 | Toshiba TZ55V61 55" Rear Projection...
Green Picture.
i suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Jan 15, 2007 | Philips 55PP9701 55" Rear Projection...
Open Questions:
Toshiba TZ55V61 55" Rear Projection Television Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
