Question about Dishwashers
Zanussi dishwasher it starts filling with water and then trips the fuse board trip switch
  • Dishwashers Master
  • 5,603 Answers
Check the heating element for leak/short to ground. If trip happens as water goes above a point that is broken.
Posted on Sep 09, 2009
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
May 19, 2015 | Stoves Dishwashers
Breaker at dishwasher trips right after water has filled.Spray arm has not turned.
There is an electrical short circuit, check/reverse the leads going to the pump or heater.. Sounds like controls and water valve are fine. If wires are not connected to the correct locations you need a new motor because it is internal.
Aug 26, 2012 | Kenmore 665
Zanussi ZSF2450 has the pump running but the front panel has switched off - booklet says contact service centre anyone know what is wrong?
The flood switch has tripped, this is either due to water in the base of the dishwasher or a faulty flood switch.
Mar 04, 2012 | Zanussi Dishwashers
Hi, my zanussi izzi dishwasher has started acting up, it will start a cycle but after a couple of minutes it trips out the main RCD in the fuse board, now i have isolated it to the dishwasher itself and...
If it trips after a few minutes of coming on , it is probably the heater which is faulty , disonnet it and try , if it doesn't trip you need a new heatee
May 02, 2017 | Zanussi 24 in. IZZI ALU Built-In...
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
My KitchenAid dishwasher quit workin no light no nothin, float switch is good, having problem troubleshooting water fill valve with solenoid???
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | KitchenAid Dishwashers
Cycle starts but water doesn't fill past heating elements.
I think that the problem is the water inlet valve if the machine is not filling at all.
If the machine is not filling to the correct level, it may be the float switch.
Apr 27, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
HOTPOINT FDW60P DISHWASHER
There is usually a float switch inside the DW body. Usually a polystyrene lump. This may be stuck in the up position, or a pool of water may still exist within the case.
When you say trips the electric - is this your wall MCB or ELCB ? If it is that then there is a major electrical fault on this machine that needs investigation.
Jun 11, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Zannussi de4744
Aquastop on water inlet tripped. Turn off and slightly undo main inlet hose. find water inlet valve and remove thin pipe from nipple. Turn m/c on for a few seconds, turn off and replace all pipes m/c will now fill and continue
Dec 05, 2006 | Zanussi 18 in. DE4744 Free-standing...
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
Owen Barnes
