Question about Taylor 632-33 Ice Cream Maker
Taylor Soft Serve machine, condenser kicking off
I have a Taylor 430-12. Loaded a mix, the mix froze about 3/4 of the way, now the reset button keep tripping and the condensor shuts off. It will start again in a few minutes, run for about 10 seconds, then shut off again.
  • Lisa Page
    Lisa Page Jun 02, 2012
    mine does the same thing. do u know what causes it?
SOURCE: Taylor 770 soft serve
press reset button very hard (the red one)
Posted on Aug 05, 2008
SOURCE: taylor soft serve ice cream machine model #y754-27
I have a gearbox,coupler,pulley etc. pulled off a y754-27
Jer 805-925-5556
Posted on Dec 01, 2008
  • 3 Answers
SOURCE: Taylor Y754-27 Soft Serve Ice cream machine
gearbox is sealed, I've never replaced one.check belts could be too tight, does it scream when you start it. check bearing at end of barrel sharp edge means needs replacing. check temperature of product disspensed on loud side could be too cold. adjust on board or needs new probe, inexpensive but a ***** to install.
Posted on Jan 21, 2010
  • 1144 Answers
SOURCE: need to know how to clean the taylor soft serve
http://www.taylor-company.com/
go to this web site and just click on operators manuals. Then either enter your model number or you can use the drop down menu.
Posted on Aug 12, 2010
  • 91 Answers
SOURCE: we have a 2 flavor
Faulty compressor contactor,faulty power board or compressor has burnt out.
Posted on Jan 30, 2011
Poor Overrun on Taylor 162-12
You cannot change the overrun on a Taylor 162. Once you've properly primed the machine and installed the feed tubes, the viscosity or how firm the product is.
I do not know of any soft serve machine that will give you an 80% overrun. You can adjust the overrun on a Taylor pressurized machine like the 8756 or the C712, but I believe the limit is somewhere around 40%.
You can email me tex@softserveparts.com or call 1-800-879-7839 if I can answer anymore questions for you.
Soft Serve Parts Supplies
Jun 02, 2017 | Taylor Ice Cream Makers
Compressor hpco code comes up on panel of Taylor soft serve ice cream machine? Does that mean lack of water to machine?
There is a very good chance. Often the water has been shut off, or a wheel is pinching the hose.
HPCO stands for High Pressure Cut Out. The high side pressure is regulated by the water valve on water cooled equipment.
These are links to parts in the water cooling system.
046686 Water Regulating Valve 3 8
048287 Condenser for Taylor Water Cooled machines Taylor 035174 Scraper BladeReplacement 17
May 28, 2017 | Taylor Ice Cream Makers
For the Taylor C709-27 soft serve machine - what does it mean when someone says it wont go in the heat cycle overnight?
The Taylor C709 is a Heat Treat machine. Most soft serve machines have to be cleaned out every 3rd night and sanitized. Heat Treatment machines heat the mix up to a high temperature that kills bacteria and allows you to disassemble and sanitize the machine much less often. I can't tell you why, but the machine you are dealing with isn't running that heat cycle.
May 10, 2017 | Taylor Ice Cream Makers
My taylor 152 only makes about 5 ice creams then won't produce any more for about 6 minutes ... why ??
The Taylor 152 is at the low end of output when it comes to commercial soft serve equipment. It is rated for 102 3.5oz. servings per hour, but only 4 3.5oz rapid servings before it needs time to recover.
Possible remedies:
When you need to serve several cones in a row, you can pull the feed tube in the top. That will help the product fill the cylinder a little faster.
You could always consider a used Taylor machine that has the ability to keep up with your demand. Soft Serve Parts Taylor Machines
Apr 07, 2017 | Taylor Ice Cream Makers
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
I have a Taylor 794 soft serve machine. The left side is too soft.
Viscosity adjustments should not have to be made frequently on these machines. If you change products a lot, such as flavors of yogurt, minor adjustments may be required. If your machine uses 3 phase electricity and it machine has been moved or any electrical work performed you may want to check the beater rotation, the beater should rotate clockwise inside the barrel viewing from the front, if you look at the gear box from the back, the pulley should be turning clockwise as well. Otherwise, there is a fine tuning potentiometer on the control, you must remove the front cover to see it. Clockwise is colder/thicker. I recommend small adjustments. It is best to read the amp draw on the motor to see what type of amps it is drawing. If your mix is soft and your motor is drawing 4 amps, you may have another type of problem such as a bad motor. The board and control can also fail giving these problems. There are many things to check in addition to these. Hope this will help you get started.
Apr 05, 2013 | Taylor Ice Cream Makers
I need pice from 339-27 ice cream mashin
Dear friend, Well if you are planning to buy an ice-cream machine.i can provide you a few links.
for 339-27 ice cream mashin 1)http://shop.ebay.com/sis.html?_nkw=TAYLOR+339+27+SOFT+SERVE+ICE+CREAM+MACHINE+AIR+COOLED
2)wvw.lucantoniblanz.tk/taylor-339-27-ice-cream-machine
3)http://www.fashioninpassion.com/index.php?jeans=simac+il+gelataio&pj=67167
Price:$2392.0 - Taylor Soft Serve Ice Cream Machine Model 339-27 for the 3rd website
the cost is ranging from $1,995.00 to $7,500.00 (cost on ebay.com)
the below link will guide you in a more better way.
http://shop.ebay.com/sis.html?_nkw=Taylor+754+33+Soft+Serve+Ice+Cream+Machine+Air+Cooled
Buy It Nowor Best Offer $7,500.00
Jul 31, 2011 | Taylor 632-27 Ice Cream Maker
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Ice Cream Makers Logo
270 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
