Question about Lexmark X5495 Printer
Every day at midnight, printer sounds alarm
Every day at midnight, my Lexmark x5495 printer sounds an alarm for about 1 minute. Why does this do that and how do I shut it off.
Steps do not reset at end of day
Try to perform a reset of the Fitbit. Follow
How do restart my tracker
When does my tracker reset and what happens to the previous day data
Your tracker resets your data to zero each night at midnight. For most trackers, your minute-to-minute data will be stored in your tracker for up to seven days without syncing. If you have a Fitbit Alta™ your minute-to-minute data is stored for up to five days. A daily summary of your activity is stored for up to 30 days.
Keep in mind that your calorie burn estimate will begin each night at midnight, so if you're up late and moving around, your tracker will adjust your calorie burn accordingly. Even if you are asleep at midnight, you will still see that you've burned some calories upon waking up in the morning. This is because you still burn calories even if you are sedentary or sleeping. Fitbit calculates your calorie burn based on information about your age, gender, height and weight.
Apr 16, 2016 | Fitbit Flex Wireless Activity Tracker...
Model 8806P101C - Purchased at HomeDepot 5-1-11- and installed same day. I water on Wednesday and Saturday and have 4 zones of watering. On those days I water all four zones for 36 minutes each starting...
Let me ask a question.
Is the time of day arrow pointing at the time of day right now?
If not, you can reset the time wheel by I think pulling it away from the body and rotating it.
If so, can you simply adjust the timer so that when it goes to the next day (10pm) it is really midnight and change any start times accordingly.
Do you need the 12 minutes between zones?
Gary
May 08, 2011 | Intermatic R8806P101C -...
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
Computer hangs during boot up after instlaling lexmark 6650 print
This is a problem I've seen with Dell PCs, what it is doing is trying to boot from the card reader on the printer. My PC had this problem, and a Dell BIOS upgrade fixed it. It would even try to boot from USB keys or mp3 players I left in the USB slot! So I have a feeling you have the same problem I had.
If you don't feel comfortable updating the BIOS, then contact Dell and maybe they can walk you through it.
Mar 30, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Durabrand hm3817dt alarm
I just bought the system yesterday and the same thing happened to me. I didn't realize the alarm was set and it kep going off at midnight. I think I just solved the problem. While the unit is off, press the standby button then the alarm button and wait for the alarm symbol to go away. This should do it.
I have another problem. Every time I turn the unit on, it comes on at about an 18 sound level waking everybody up. This happens even if the radio has been playing on low before turning it off.
Any solution to this problem would be appreciated.
David.
vikdave2006@yahoo.com
Jul 12, 2008 | Audio Players & Recorders
Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Faulty Alarm
Per the second review at this site: http://www.amazon.com/75290-Spacemaker-Player-Built-Subwoofer/dp/B000051SEK "And if an alarm sounds at midnight, UNPLUG the radio's power cord from the wall receptacle, WHILE that alarm is sounding. Wait at least 20 seconds, and re-plug to power. Sleep in heavenly peace!" Perhaps this will do the trick? If not, the phone number to call is also listed in that same review. Good luck!
Mar 24, 2007 | GE Spacemaker 75290 CD Shelf System
Lexmark X5495 Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
