Question about Kenmore Elite 45986 Front Load Washer
F28 same thing
    President:
  • 1,776 Answers
This code is not good news, I'm afraid. The F28 code on the Kenmore Elite can indicate a problem with one of the control boards. The problem is that it's nearly impossible to tell which board....so you can see the delimma. The wiring harnesses are prone to loose/intermittent connections, so you can try unplugging and reseating the electrical connections (disconnect power from machine first) and see if that will clear up the problem. Pay particular attention to the connection at the motor control board. If reseating the connections does not clear up the problem, I would suggest contacting the manufacturer. There has been some history of problems with the control boards and wiring harnesses in these machines and the manufacturer might work with you, but I make no guarantees. I would also recommend contacting an appliance service technician for assistance if the unplugging/reseating thing doesn't work out. I am really sorry for your trouble and I hope this helped somewhat. Best wishes.
Posted on Sep 09, 2009
  • 15,935 Answers
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
  • dominic_c Jan 09, 2011
    Awesome!!! Back to washing clothes. Used contact cleaner and a cotton cleaning patch to clean both ends of the serial bus cable. Ran the washer through a cleaning cycle and then washed a load. Will reassemble and keep my fingers crossed. Thank you so much for saving me so much money! Don in Washington.
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Code f28
Hi, the error code F28 means one or both of these parts are bad.
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28. If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It gives a F28 code. What is that?
F28 is a motor controller error... Try unplugging the machine for a minute or two, then starting it again. If no good, you can remove the access cover and check the connections to the motor... BE SURE TO UNPLUG FROM WALL FIRST...
Peace,
Mar 30, 2010 | Kenmore Elite 45986 Front Load Washer
It was putting out a error code of f28 I changed the main board on the inside of the washer no it wont run the last spin cycle but it will do every thing else was there anything else I was supposed to do...
F28 error means the CCU(central control unit) lost communication the the MCU(Motor control Unit) for an HE2 washer.
I would look inside the lower front panel and get the tech sheet and run a diagnostic test per the instructions... See what comes up. Review troubleshooting for the F28 make sure you did not miss anything.
I hope this helps
Mar 20, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
5E Washer - Won't Fill / F28 Error
check if hoses are reverse when installed
May 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
221 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
