Wireless laptops and desktop pc show status connected to the router but neither connect to internet
  • YourZEN
    YourZEN May 11, 2010
    Restarted the internet modem after al the connections have been made ?
  • 29 Answers
Take the internet connection from the back of your router and plug it in to one of your pc's. try logging into the internet. this will tell you if the network is available to the router- if it is-
go to wireless pc
go to run , type cmd
in black window type ipconfig/all hit enter
the ip of your router will be displayed.
go to your browser, type in the router address where you usually put a web site name. hit enter
a window should appear asking for login and password to the router. if you could get to the internet on the cable and can't from the router the router is not set up properly and you must log into the router and set up the way it talks to the internet.
Posted on Sep 10, 2009
Linksys stop connecting to computer
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. check with the ISP to see if you have an outage.
8.check status lights to if the power and the Ethernet are functioning properly.
9. power to the router > Ethernet cable connected> ISP shows connectivity.
Jun 17, 2011 | Computers & Internet
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
Wired connection don't work, but wireless do.
You can use your USB connection on your Cable moden for your Desktop PC and then bridge to another through that computer's Ethernet connection to another's Like your Laptop. you can go into your network center on your desktop and go to your connection's status, then go to the sharing tab and check "Allow other computers to access this connection to the internet" or such as.Thsi can work for you Xbox 360 as well, it worked for me
May 06, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My router is connected but my pc cannot get on the internet, says ie cannot display this page? I have XP serv pack3. My laptop is Vista. Laptop works great, only problem is with desktop. Is my ie disabled?
HI,
check in the Belkin Wireless Monitor that the DCHP status is enabled for the desktop PC.
On the PC desktop, select Networkconnections, show existing networkconnections, select your connection, properties, scroll to the TCP/IP settings, select and check properties you should have selected "obtain IP address automatically.
Restart your PC. If you still have problems close down your PC and laptop, unplug modem from electricity, unplug router from electricity, wait 2-3 minutes, put the modem on again, put the router on again, start up your PC and then start up your laptop.
This procedure works always for me if I loose my connections. Does it solve your problem?
Aug 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Help with belkin wireless router as only internet connection
If your pc does indeed say your connected to the net. Then check your internet browser, as that will most likely be your problem.
Mar 14, 2009 | Computers & Internet
Cannot get onto internet
disable the firewall on control panel.
check all the properties boxes on the network
connections and make sure firewall is disabled.
access the router setup and make sure that VCI is set to manual
and that you enter in the settings yourself (eg: 0,38 for aol broadband). Don't leave VCI, etc on auto, the router can't handle it.
Jan 09, 2009 | Buffalo Technology WHR-G54S Wireless...
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
No internet access
disable the other adapters and try agan...
then use use the set up Home or small office networking wizard in the left to complete it
hope it worked !
Mar 10, 2008 | Computers & Internet
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
ASUS WL-520g wireless router and hutchison broadband connection problem
You need to contact your ISP if the internet connection is not there....
Nov 06, 2007 | ASUS WL-500g Wireless Router (WL500GDLX)
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
