Question about Refrigerators
My refrigerator keeps freezing my food, even on the lowest setting. what part needs replaced?
  • 555 Answers
Thermostat appears to be broken.
Posted on Sep 09, 2009
GE Profile pss26mgpa. Food keeps freezing no matter the temp setting
Set the temp to the lowest setting and see if the damper is closed and not letting air into the food section. If it is, then you will need to replace the damper. Here is that part to order.
Jan 19, 2013 | Refrigerators
Just recently, even at the lowest settings (to keep temps warm as possible) the refrigerator is so cold the milk and OJ is freezing. Any advice on what might be the problem?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | Kenmore Side by Side Refrigerator
My refrigerator freezes my food and drinks even at lower setting. The freezer is at the lowest setting and freezes my food like rocks.
There is a thermostat inside the casing telling the fridge to keep cooling - forever.
Replace it
Oct 28, 2010 | Refrigerators
Refrigerator is freezing food
your damper door located between the refrige and freezer compartment is iced up fully open,you need to defrost it, then see if this closes when the cold control is adjusted
Jan 16, 2010 | Frigidaire FRS26H5AS Side by Side...
Kenmore side by side coldspot, model 5687
I'm not trying to be a smart ***,but a lower temperature setting would make it colder.Try using a higher temperature setting.If this was just a poor choice of words you may need to replace your thermostat.
Jun 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerator kenmore
fresh food thermister should be checked. also the damper assembly that regulates cold air from freezer to fresh food side.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Food gets frozen
If your refrigerator freezes its contents, even when the cold control is set to its lowest setting, its cold control is probably defective. Call an appliance repairperson. As a rule, refrigerators are designed to maintain 37 to 40 degrees F in the refrigerator box and 0 to 5 degrees F in the freezer box. Setting either compartment to lower temperatures generally costs you extra in energy dollars. If the icemaker keeps making ice, even when full: 1) Lift the bail wire to shut it off. 2) Empty the bin, remove the icemaker, clean it, and reinstall it. 3) If the problem persists, consider having an appliance repairperson remove and replace the entire icemaker and valve, a relatively affordable repair. With this type of problem, it's often better to replace the unit rather than to pay for
Jan 18, 2006 | Hoover HCA331FFK
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
