Question about Compaq Computers & Internet
I have 3 solid lines across the centre of my screen,any ideas
    Scholar:
  • 87 Answers
Broken LCD or the ribbon cable (that connects the main board to the lcd) has broken wires in it.
Posted on Sep 09, 2009
Thin black line running across centre of the
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 20, 2014 | Televison & Video
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Horizontal line across screen
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Sep 12, 2009 | Memorex Televison & Video
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
I have a solid white line going across the centre of my screen.when turned on the picture is split in 2
Try an external/different monitor, also if running windows you can try a fallback to a previous restore point. Also try the monitor on a different pc, if it's a desktop. That way, you will know if it's the video card in the pc.
May 04, 2008 | Computers & Internet
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Printing solid black lines 1/2 high where the actualy print should be
the printhead resistor are done , you will need to replace the whole printhead
Jan 21, 2008 | Apple Epson Stylus Color 740i InkJet...
Solid yellow line on recipients screen
I lost my drive for my crative no. PD1130
Nov 24, 2007 | Creative Labs WebCam Live!
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Computers & Internet Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
