I have frigidaire stacked washing machine/dryer. The washer overfills and this happened before. I believe it is some sort of cut off sensor that has failed. Any help on how to do this repair?
If it fills with water and starts the cycle and
the water keeps running in then your water inlet valve on the back where the
water supply comes in is sticking. It needs replacing. This is also the problem if it happens sometimes.
Your pressure switch stops the
water and allows it to start the next cycle. It's a switch either in the
control panel or at the top of the tub with a small tube connected to it which
goes down between the inner and outer tube. As the water level increases the
air in the tube is compressed until there is enough pressure to make the switch
stopping the water from filling. This tube can get clogged and the switch won't
work. Remove the tube and clean it out. Blowing on the tube when it's still
connected to the switch will make the switch if it's working and clear.
You are correct. Sounds like the pressure switch is broken or leaking and may need to be replaced.
To replace it, the back of the appliance needs to be open, there is a plastic tube that is connected to the tub and to a shiny round piece. That part is the pressure switch. It should have a part number engraved so it can be used to order a new part.
