Question about Polaroid SprintScan 4000 Film Scanner
Had successfully scanned 12 slides when this message appeared: "Communication error: Command complete. Please make sure the device is properly connected and terminated." I have done the following to rectify problem w/o success. Turned off computer. Turned off scanner. Turned on scanner. Turned on computer. Did this 2x. It acted like it wanted to work, but then I got the same error message. I have been using this scanner for 7-8 years and have never had a problem until today. HELP!!!
    President:
  • 2,017 Answers
Kindly chage the data cable of scanner and port also.
Posted on Sep 10, 2009
Good day, why craftsman diagnostic scanner show 'communication error' whenever it's scanner Nissan vehicles
PDF]Communications Could Not Be Established with Your ...
www.wisconsinvip.org/WivipPublic/PDF/.../noncom052108.pdf
May 21, 2008 - computer alerts motorists of problems with the vehicle's emission control ... tampered with and the connection to the on-board diagnostic (OBD) ... itspower from the same circuit as the cigarette lighter. ... scan tool, connected to the data link connector (DLC) under the dash, not ... General Program Questions.Missing: craftsman ‎whenever
[PDF]OBDII ABS and Airbag Scan Tool - Actron
https://actron.com/craftsman/scan-tool/.../568593-Craftsman-39853-MN...
OBDII ABS and Airbag. Scan Tool. Model 39853 .... OBD II Diagnostic Trouble Codes (DTCs) . .... Program Mode . .... Error Messages . ... Vehicle Communication Fault ...... No warranty (expressed or implied) can be made for its accuracy or completeness... Go to www.actron.com/craftsman to download the Scanning Suite.
Scan Tool Help
www.scantoolhelp.com/
A scan tool is a must for automotive diagnostic work today. ... 1996 and newervehicles (one exception is Nissan), and (2) counting the series of flashes can be confusing. ... II monitors (ready means the monitor has completed its self-check process). ... with bidirectional (two-way) communication capability and the proper ...Missing: craftsman ‎whenever
Automotive Diagnostic Scanners -- OBD-I and OBD-II
www.mikeogara.net/improve_your_car/auto_scanners/
Jan 31, 2016 | Nissan Cars & Trucks
Hp 3500C communication error
Restart the PC and the scanner and try again. Make sure you installed the right drivers, make sure that the PC see's the scanner, check devise MGR and look under printers, interface devise.
Apr 03, 2013 | HP ScanJet 3500C Flatbed Scanner
Hello, I can't use my Yahoo on this PC. can start and when I can see all my contacts comes a message that yahoo having a problem and has to be closed.The message comes from Windows with an report to...
Uninstall Yahoo Messenger using Revo Uninstaller...>download Before starting to uninstall a program be sure that it is not running. So check your taskbar at the bottom of your screen and near to your system clock, if the icon of the program you want to uninstall is there right click on its icon and select "Exit" or "Quit" or equivalent command to close it. Then select the program and start the "Uninstall" command. Uninstall process with Revo Uninstaller Pro starts the uninstalling wizard, which shows you what is happening on every step of the uninstalling procedure. During the uninstall Revo Uninstaller Pro tries to run the built-in uninstaller of the uninstalled program, if it works properly let it to do its job, but if it is not working properly here you will see an error message that you will have to skip ( ignore ). Then select an uninstall mode and press "Scan" button to continue further to the next step of the wizard. After the scanning completes you will see the leftover Registry items, files and folders, review, verify and delete them
Aug 10, 2011 | Yahoo Messenger
Window Vista problem??
If you receive this error message or encounter difficulties when attempting to launch Pro Tools using Windows Vista disabling DEP may solve the problem.
This option disables "Data Execution Prevention", a feature of Windows that can sometimes cause errors. This won’t harm anything, but also isn’t always necessary.
How to Disable DEP:
1. Click "Start"
2. Click "All Programs"
3. Click "Accessories"
4. Right Click on "Command Prompt"
5. Left click on "Run as Administrator"
6. Click the Allow button if it asks you for permission
7. Type or copy and paste this into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOff
8. Hit enter and you should see the confirmation: Operation Completed Successfully
9. Reboot and DEP should be off.
If you would like to re-enable DEP enter the following into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOn
Hit enter and you should see the confirmation: Operation Completed Successfully. After restarting the computer, DEP will be re-enabled.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
Scanning
Hi saly_60,
You can try the following steps to resolve the issue:
1. Connect the USB cable directly to a USB port on the computer Ifyou are connecting the device through a USB hub* or other USB device,disconnect it and try connecting directly to a USB port on thecomputer. If successful, the problem may have been with the device.
*Somescanners are powered by the USB connection. This is why connecting thescanner through another device, such as a USB hub, may prevent thescanner from communicating properly with the computer.
Connecting the cable to the your device.
usbtoprtr.gif Connecting the cable to your computer.
2. Check USB Connections Youshould disconnect and reconnect the USB cable at both ends to ensurethere is a secure connection on the device side as well as the computerside. It may also be necessary to try a different USB port on thecomputer. Additionally, you may need to disconnect other USB devices,temporarily, in order to determine if a conflict exists. .
  1. Disconnectone end of the cable and then reseat it ensuring the cable is firmlyseated into the USB port. If the USB cable is plugged into a hubinstead of directly into the computer, try connecting the USB cabledirectly into the computer.
  2. Repeat step one to reseat the cable on the other end.
  3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  4. Make sure the correct USB cable type is being used.
  5. Incorrect (A to A) USB Cable
    Correct (A to B) USB Cable
3. A device attached to the computer is blocking communication If you have more than one device connected to your computer, thenit is possible that some other device is blocking proper communication.
  1. Check to see if there are any devices (other than USB keyboards or mice) connected to the computer.
  2. Disconnect the device(s) and restart the computer.
  3. Once the computer has restarted, attempt your process again.
4. Press the ON/OFF button to power on the device. The device has an <ON/OFF> button.
  1. Connect the power cord from the device to the electrical source.
  2. Press the <ON/OFF> button.
  3. Wait until the device has completed its cycling process before submitting a job request or completing installation.
5. USBSCAN.SYS USBSCAN.SYS is a Windows system fileand required by the scan driver. If the system file is missing, anerror message will appear while installing the scan driver or willappear when attempting to scan. Search for this file and direct theinstallation to the appropriate path.
Search USBSCAN.SYS file on Windows XP:
  1. Click 'Start', 'Search' and select 'For Files or Folders'.
  2. At 'Search Results' window, type usbscan.sys in 'Search for files or folders named' field.
  3. At 'Look in' drop-down menu, confirm your computer's hard drive is selected. In most cases, C: is the computer's hard drive.
  4. Click 'More advanced options' link.
  5. Confirm checkmarks appear beside 'Search system folders', 'Search hidden files and folders and 'Search folders'.
  6. Click 'Search' button.
  7. Once search has completed and if the file does not exist, download a copy of usbscan.sys from here (Right click and select ‘Save Target As’).
    1. Ifthe file exists and a message appears while installing the scan driver,direct the installer to the appropriate path. For example,C:WINDOWSsystem32drivers.
  8. Close the 'Search Results' window.
Search USBSCAN.SYS file on Windows Vista:
  1. Click the Start button.
  2. Inthe Start Search box of the Start menu, type 'usbscan.sys' (without thesingle quotes) and then press 'Enter' on the keyboard.
  3. Once search has completed and if the file does not exist, consult the computer manufacturer.
Uninstall and Reinstall the Driver If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them. Caution:Uninstalling means deleting software, such as MP drivers, from thecomputer. Once the software has been deleted the unit cannot be usedthrough the computer until the software has been reinstalled.
Note:Login as a user with Administrator privileges to uninstall onWindowsXP/2000. Turn off any programs running in the background, suchas antivirus programs and firewalls before begining.
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
6. Reinstall the Drivers
Use the CD-ROM that came with your printer or download from canon website.
Sep 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a scanner problem on my HP4150 Photosmart all-in-one printer. When I try to scan with from the HP Solution Center I get three error messages. 1 windows error message "A problem caused the program to...
Since you have the latest driver and software from the HP site, you should completely Uninstall the software from your computer.
Then you may need to add an environment variable to your system. If you are using Vista, click on Start, right-click on computer and select Properties then click on Advanced system settings. If you are using XP, click on Start then right-click on My Computer.
On the System Properties dialog, select the Advanced tab and click on Environment Variables. Look for a variable named devmgr_show_nonpresent_devices. If it is not in either the user or system variables list, clock on the New... button for either list and add this variable name and give it a value of 1. Click on OK to close the dialog boxes.
Open up Device Manager. In the View menu, select the Show hidden devices option (there should be a checkmark next to it). This will reveal additional devices in the list. Open up the Printers node and make sure your printer is no longer listed here. If it is, right-click on it and select Uninstall. Disconnect your printer from the computer and reboot the computer.
Once the computer reboots, reinstall the HP drivers and software making sure you don't reconnect the printer until the installation wizard tells you to. Retest to make sure everything is working correctly.
Jul 10, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP Photosmart 3110 All-in-one - Scanner function not working
Scanning requires two-way communication between the computer and the scanner. Usually the error that you describe above indicates an issue with the USB connection. First, make sure that you are not using a USB hub. Try a new USB 2.0 (A-B) cable that is under 6' long. Try using a different USB port on the computer.
If the problem persists, check the Device Manager to see if you have a USB driver problem. (For most versions of Windows, press the Windows key + X to quickly access the menu with the Device Manager.) Expand the section labeled Universal Serial Bus controllers and look for an exclamation point or an X. Similarly check for any issues in the Devices and Printers section of the Control Panel. The All-in-One should be listed as a printer and a scanner.
I hope this helps. If you are still having problems, please add a comment with the OS version on your computer. That can help identify additional issues that could be involved.
Apr 04, 2017 | HP Photosmart 3110 All-In-One InkJet...
Full system scan not getting completed
Open NIS and run LiveUpdate. Keep re-running LiveUpdate until it says that there are no more updates. Reboot the system if prompted to do so (you may want to reboot even if it doesn't say it is required, just to be sure everything got replaced properly). Open NIS again, select Tasks and run a Full System Scan. The error message should not appear again.
Mar 19, 2009 | Symantec Norton Internet Security 2008:...
Error Message "Communication Not Available
Please open the link and follow the instructions this will definately resolve the issue, and please respond with comments to impove better service and resolution
Communication Not Available" Error When Sending a Print Job
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=true&docid=2AA10ED87ADC4C0EE040A68F5B285B98&journalid=45AF3C8CB5A7BDF9E040A68F272874F0&l=en&s=gen
Regards
Feb 04, 2008 | Dell 810 All-In-One InkJet Printer
Scanner Error Message
I understand that you are unable to scan from computer as well as from the printer front panel.
The issue that you are experiencing might be with the USB drivers unable to detect the printer.
However, please follow the below given instructions to resolve the issue.
Check for the communication between the computer and the printer by following the below given instructions:
To isolate the issue I suggest you to try scanning from Imaging for Windows which will scan from the all-in-one product using TWAIN software instead of the HP software.
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click Programs then Click Accessories then Click Imaging.
3.From the Imaging application, click File, and then click Select Device.
4.Select the HP all-in-one device from the TWAIN source list.
5.Click File, and then Acquire Image.
If you are unable to scan from the above steps, then confirms that the issue is with communication.
Refresh the USB composite drives to resolve the issue.
1. Right-click My Computer (in Windows XP, click Start first), and then click Properties.
2. Select the Hardware tab and then click Device Manager.
3. Click the Plus (+) sign next to Universal Serial Bus Controllers.
4. Click the USB Composite Device entry to highlight it, and then click Action and then click Uninstall. If a screen appears to confirm the deletion, confirm the deletion.
5. Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
6. A New Hardware found screen may appear, click Next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
Then try scanning, even if the issue still persists uninstall and reinstall the USB drivers:
1. Save and close all programs that are currently running.
2. Click Start, select Shut Down, and choose Restart the computer.
3. Press the F8 function key, this will display the Windows Startup menu.
4. Select Safe mode.
5. After Windows loads in Safe mode, right-click the My Computer icon and select Properties.
6. Select the Hardware tab and click the Device Manager button.
7. In the Device Manager Window, double-click the Universal Serial Bus controllers.
8. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
9. Click OK to confirm the removal of the device.
NOTE: Repeat steps 8 and 9 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled.
Now, restart the system. The system automatically detects and reinstalls the USB port.
Then try scanning this should resolve the issue.
If you are unable to scan from software, try running the scan diagnostic utility from the below weblink:
Here is the web link to download scan diagnostic utility:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=oj-45265-1ScanDiagnosticUtility_ver_1.5.exe
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Even if the issue still persists uninstall the complete All-in- one software and reinstall it.
This should resolve the issue.
Regards,
Lawrence
Jan 10, 2008 | HP PSC 500 All-In-One Printer
Open Questions:
Polaroid SprintScan 4000 Film Scanner Logo
119 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Joseph Gallucci
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
