IT DOESNT MATTER HOW MUCH YOU TURN THE CONTROL IT DOESNT CUT THE HEATER ON. BUT YOU CAN JUMP IT OUT AND IT WILL WORK FINE. CAN THE CONTROL BE REPLACED BY ITSELF WITH OUT REPLACING THE BOARD. IF NOT WHERE DO I GET THIS BOARD AROUND CHARLOTTE, NC.
It is hard to say without knowing weather knowing if this is a milivolt or electronic heater. In ether case you can replace parts, just witch parts is the question. A milivolt heater the thermostat will be sold as a unit that screws onto the faceplate and has a temp probe that will snake around to the water header and slip into it. An electronic heater will have a thermister that will also go into the header and ether have wires that plug into it or wires connected to it that plug into the board. This is often the problem with these and are cheap and easy to fix. If it is not this then it will probally be the board but it will usually only go bad if it has gotten wet. As for where to get parts any pool store can get them if they don't have them on hand or go to your heaters web site and find a retailer through them. I hope this helps, good luck.
I want to enjoy a nice Jacuzzi in the house :-) I don?t have any knowledge on the pump subject and...
(More)
I want to enjoy a nice Jacuzzi in the house :-) I don?t have any knowledge on the pump subject and would like to learn, types, sizes, cost, models and of course what to buy?.
Our pool filter turns off after about 30 minutes, it seems to get hot and then will not turn back on...
(More)
Our pool filter turns off after about 30 minutes, it seems to get hot and then will not turn back on for many hours. the pool is new.
Is the Hayward variflow filter model SP710 O. K. to use with a 2Hp/1600 w pump? (Thanks for your...
(More)
Is the Hayward variflow filter model SP710 O. K. to use with a 2Hp/1600 w pump? (Thanks for your help in advance. Chris.)
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
