Question about Maytag Neptune MAH5500B Front Load Washer
Can''t get my clothes out... water still inside
Small maytag frontload washer.... I can''t get my clothes out... water still inside and the door will not open and allow me to take out clothes.... letters...nd keeps flashing? right before it broke it made a loud clicking/ticking sound and new cycle will not start just buzzing........ how can I fix please?
    Problem Solver:
  • 12 Answers
Does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Posted on Sep 09, 2009
Frigidaire frontload washer filling up constantly
do not set knob to open position and open door ....I did this and flooded new construction. What happened to me is that my contractor took out the screens to the inlet hoses and this allowed small chunks to get through and lodge in solenoide valve causing it to stick open and allow for constant water flow......simple disassemble, clean, and PUT SCREENS BACK IN! they are there for a reason...
Jun 30, 2012 | Frigidaire GLTR1670A Front Load Washer
Hole in Maytag Neptune front load washer door and flaking or melting of door.
I've owned the same Neptune since 1999 and had this problem happen to me twice, the first time the inside molded plastic door melted through in a circular pattern and had to be replaced. The fact that it was circular indicates that something was rubbing during the high speed spin. That something was a stiff bottomed duffle bag that was rubbing on the plastic door during high speed spin. The washer was full of other clothes that didn't allow the duffle bag enough room in the washer tub, hence it pressed against the plastic door. The second time it happened I got a circular groove melted in, but not through, the plastic door... caused this time by a small child's back pack. I would make sure "rigid" items have enough room to "float" in the tub cavity by not putting in other clothing that over packs the washer.
Oct 15, 2017 | Maytag Neptune Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    How do I get smell out of my frontloading washing machine?
    Run a load of just clorox water, no clothing. This will kill the mold spores and eliminate the smell. When not in use, keep the door open to allow air to circulate. That will prevent mold from regrowing.
    Jun 28, 2010 | Frigidaire ATF6000ES Front Load Washer
    My frontloader starts out fine , but when time to drain, it spins and only a small amount of water comes out,the spin cycle is so load and moves the washer while spinning also the cycle ends and the...
    check water pump , from your discription i beleive you have a blockage before the pump this would account for the small amout of water removal
    NEVER OPEN MACHINE CASE WITH REMOVING POWER PLUG FROM THE MAIN POWER SUPPLY
    Jan 16, 2010 | Frigidaire ATF6000ES Front Load Washer
    Mildew smell
    PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
    Whirlpool bought MAYTAG about 3 year ago.
    THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
    NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
    AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
    ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
    Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag frontloader washer, seems to wash ok but won't spin water
    madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
    Aug 07, 2009 | Washing Machines
    Black mold on washer door seal
    this is a very common problem with the neptune washers.
    use a javex and hot water solution and scrub the rubber boot.
    you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
    There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
    this will allow for air movement in the washer
    May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    The Maytag wahser stops and the door is unlocked
    Something large in the drain pump could be the problem. You might need to remove it and take a look inside.
    MAH2400AWW Frontload Washer drain pump removal link:
    http://blog.myspace.com/index.cfm?fuseaction=blog.view&friendID=58843118&blogID=364038999
    Jan 31, 2008 | Maytag MAH2400A Front Load Washer
    Maytag frontload washer door is leaking
    Yes you can do it. the door boot has come off the tub opening. first you will have to push on the door boot (gray rubber)on. There is a grove that slides into the metal opening in the washer. make sure the the door boot (gray rubber)lays flat against the outer opening. then with the spring at the bottom . start at the top put the wire in the rubber grove. until you get the the spring then pull down on the spring and tuck it into the grove.. I hope this helped [lease let me know if you get it... krazytech
    Sep 13, 2007 | Washing Machines
    Maytag Neptune MAH5500B Front Load Washer Logo
    242 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
