Question about Xerox WorkCentre M15i Laser Printer
How to change initial mode to copy mode
How to change initial mode to default to copy mode not fax mode when copier is turned on.
  • bill773 Sep 10, 2009
    There is no initial mode on this model. The last mode the copier was in (Fax, Copy or Scan) is the mode that the machine will be in when it is turned on. I am answering my own question with info I obtained from the Xerox Support website. http://www.support.xerox.com/SRVS/CGI-BI...)
    So if your Mode Button on the op panel is worn, your will have to replace it.
When faxing certain out of state numbers it shows wait in Job status then says TX Failure. Not sure how to get out of wait mode?
Is a long distance code required? Is there a problem on the other end? If not, you can reset fax board by entering */1 mode and initializing 100/102/103. If this is performed, fax settings will return to factory default. If problem persists, certain VOIP settings will need to be changed.
Oct 02, 2014 | Toshiba E-Studio 4540c Copy/print/scan/fax
Fax default
I found this online today:
Mode Timer
The (Brother MFC-8480 DN) machine has 3 mode keys on the control panel: Fax, Scan and Copy
You can set how much time the machine takes after the last COPY or SCAN operation to return to FAX mode. If you choose OFF, the machine will stay in the mode you last used.
1. Press MENU, 1, 1.
2. 2. Press up/down arrows to choose the amount of seconds or OFF. Press OK.
3. 3. Press STOP/EXIT. I haven't tested this yet, as the machine I'm trying to adjust is at my workplace, but maybe this answer is what we're looking for.
I
I
Nov 23, 2011 | Brother MFC-8480DN All-In-One Laser...
When an incoming fax is arriving our fax at work is beeping very loudly, how do you turn it off.
Hello, it may be possible the the fax is in diagnostic mode or the ringer volume is turned up. 1) go to the administration tab on the control panel 2) go down to the initial setup 3) go to fax setup menu 4) go to fax receive settings 5) Check the ringer volume should be set to low (default) or to off for no sound. In the troubleshooting menu - set the fax speker mode to NORMAL (default). I hope this will assist with your problem.
Jan 13, 2011 | HP® LaserJet M5035 MFP Laser...
How do i change the default from fax to copy on my mfc-8840-D?
the default setting is fax press the copy button to enter copy mode.you can only change or adjust the number of minutes or seconds it stays in the copy mode from the mode timer button after that it returns to the default mode
Mar 29, 2010 | Brother MFC-8840D All-In-One Laser Printer
Fax is stuck on manual mode. how can I change. When I try to change modes, is says that DR mode in in use.
I had this problem too, I just fixed it! DR = DISTINCTIVE RING, this means you have it turned on. To turn it off go to menu, fax, miscellaneous, distinctive and select OFF. Now go to back to initial setup and select your mode!
Mar 03, 2010 | Brother MFC-440CN InkJet Printer
We have a canon imageCLASS 2220 coper/fax that is set to default to fax when the power is turned on or the machine is idle for a few minutes. How can we get this default changed to copy instead of FAX?
I need to change the IP address on my canon imageclass 2220. I have moved locations and I know they are preset on the machine HELP I know I am overlooking something
Jan 18, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Change default ptr setting for lexmark x8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
PRINTER STAYS IN FAX MODE WHEN I WANT TO PRINT
if you push the copy button you will be in copy mode.
are you saying you want your default to be in copy?
Apr 19, 2009 | Office Equipment & Supplies
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Fax machine picking up all calls
You must set the FAX RECEIVE MODE to FAX ONLY. The factory default is FAX/TELEPHONE. You can find the proceedure to change FAX RECEIVE MODE in your owners manual. IIf you don't have an owners manual, try pressing the MENU button, then scroll to one of the following: INITIAL SET-UP, FAX SET-UP, OR FAX RECEIVE MODE. One of these should get you to the FAX ONLY receive mode setting.
Aug 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Xerox WorkCentre M15i Laser Printer Logo
15 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
