Question about Compaq Audio card Sound Card
No sound at all when start up orage mute light
No sound at all when start up orage mute light on all the time
no sound controls to adjust curser will not activate sound
controls.
  • peterpride53 Sep 10, 2009
    I have now got information to fix the sound problem
    many thanks for your assistance. Peter Pride53.
  • peterpride53 May 11, 2010
    Yes I did get the solution to my problem but I could not download the information as my laptop is not connected to the internet, can I download onto a disc to transfere to my laptop.
    Scholar:
  • 150 Answers
Try to follow the following steps;
1. Start, then Run, then enter REGEDIT to open the Editor
2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
4. In the right-hand pane, click ONCE to select the UpperFilters entry
5. Make sure the UpperFilters entry is highlighted, press Delete, then Yes.
6. In the right-hand pane, click ONCE to select the LowerFilters entry
7. Make sure the LowerFilters entry is highlighted, press Delete, then Yes.
8. Close the Registry Editor by clicking File, Exit.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Posted on Sep 10, 2009
My Panasonic cf-w8 is mute? How do I unmute it? Does the Fn button have something to do with it?
Well the FN key could have set the mute on if the mute key was also pressed.
Click the megaphone at the bottom right near the time and open the audio properties and volume control. Check to make sure the mute is not checked.
You can also click Start/Control Panel and look for Audio or Sound and adjust to make sure the mute is not check.
On your keyboard if you Press and Hold the FN function key at the lower left portion of the keyboard then you can hit the key that has the megaphone with an X across it to take the mute off.
Some laptops have 3 buttons that control the volume. One for turning the volume up, one for turning the volume down and one for muting the volume.
May 02, 2012 | Panasonic Toughbook W8 Rugged Notebook -...
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
Speakers are hooked up but no sound
May 02, 2012 | ASUS Essentio Desktop with Intel Pentium...
Volume is mute
There is probably a button or key you can press to unmute the volume. Most times you have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the key that has the megaphone with the x across it.
You could try right clicking on the megaphone at the bottom right near the time and adjust the volume or properties. Remove the check mark from mute.
Or you can look for the Audio Sound properties in the Control Panel. Click Start/Control Panel and look for Audio Sound. Open it and remove the mute check mark if it is on the volume controls.
Apr 29, 2012 | Computers & Internet
My cursor moves around but to get any where or scroll I have to left click every time
Enter your control panel from the START menu select CONTROL PANEL open it scroll down to mouse and adjust settings there.
Apr 07, 2012 | HP Computers & Internet
Looks like the monitor is showing sound on mute....how do I turn it up
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
hope this helps
Aug 08, 2011 | Computers & Internet
How to removed mute to my computer
hope this helps
Jun 15, 2011 | Dell Audio Players & Recorders
How to removed mute my speaker
hope this helps you
My Mic is on all the time it is also coming through the speakers so when i turn external speakers on there is an huge feedback
See Adjust volume below
To use any microphone with your computer you will need to enable it in control panel. Instructions are for Windows XP but are similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and the volume slider is at the top of the scale.
Ensure the MUTE ALL box isn't checked before closing window.
Click VOLUME button in SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. The same applies to 'Internal MIC' if you are using a laptop with built in microphone - this must be enabled/ disabled separately to the external MIC.
To adjust audio volume.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You can also put a check mark in the box to show the volume control icon on the Task Bar so you can go straight to it to in future
Feb 10, 2011 | Toshiba (P000257700) Microphone
Pc sound is not working right now hepl me
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
